It is currently Tue Nov 10, 2026 8:11 am
Post Posted: Mon May 28, 2012 10:59 pm
why doesn any body just have em kickin around lol
cause cause there rare or wat
in need of 1 and cant find any at all :(
dodgy brothers mechanical
Post Posted: Mon May 28, 2012 11:01 pm
If you are refering to sierra diffs, they only came out in 95-98 WT maruti's.
Post Posted: Mon May 28, 2012 11:02 pm
and the rear of a jimny
so hard to find a R&P
Post Posted: Mon May 28, 2012 11:04 pm
can you ask if suzistore can bring a maruti R&P in on their next container??
Vehicle: '96 LWB trayback
Post Posted: Mon May 28, 2012 11:13 pm
I've previously bought them through Suzifour wreckers in Sydney on 2 seperate occasions.
~$300 for a complete centre to my door overnight (Sydney - Newcastle).
02 9673 3000.
FYI: The ratio you're looking for is 4.09:1. 45/11teeth. Using the correct description might help you source the correct part.
Post Posted: Mon May 28, 2012 11:15 pm
Jims are 4.09.
Jims are 4.09.
Jims are 4.09.
Are maruti's really 4.11 or 4.09?
I dont know how the rumour Jims with 4.11 started. Sounds like no one counts teeth.
Online
Post Posted: Mon May 28, 2012 11:20 pm
I have a 4.11 here you can have.
1l diff that was full of water. :thefinger:
Post Posted: Mon May 28, 2012 11:33 pm
well i have a 4.11 in the rear of 2 other jimny twin locked with reduction gears and haven been a problem so if i can find a 4.11 ill be happy
suzi store want a casual 770 for a rear diff centre alien
Post Posted: Tue May 29, 2012 6:51 am
If their Maruti have you tried to get them direct out of India? I've just received a whole box of bits that I ended up sourcing direct with a bit of googling and a couple of emails?
Post Posted: Tue May 29, 2012 7:11 am
so you have different ratio R&P for your front a rear of your jimny, that must work well in 4x4. wouldn't cause windup at all
Post Posted: Tue May 29, 2012 7:31 am
Jims are 4.09.
Jims are 4.09.
Jims are 4.09.
1L sierras = 4.11:1.
NT Maruti = 4.11:1.
WT Maruti = 4.11:1.
I believe that 4.09 and 4.11 are so close it would make no difference if you mixed and matched them.
Post Posted: Tue May 29, 2012 8:56 am
Are Sierra 1.0 diffs useful for the jimny? I have a few left over from Frog.
Post Posted: Tue May 29, 2012 9:05 am
Some early 4wd's came stock with front diff slightly higher ratio than rear,
apparently a safety thing for steep climbs and decents, to aid in steering straight?
I have no proof of this, just old peoples stories.
Post Posted: Tue May 29, 2012 9:06 am
Rear wouldn't as Jimmy are 1.3 size, not sure about front though as there smaller in size
Post Posted: Tue May 29, 2012 9:55 am
Jims are 4.09.
Jims are 4.09.
Jims are 4.09.
NT Maruti = 4.11:1.
WT Maruti = 4.11:1.
I agree, But every Jim drive thinks they have 4.11's.
Post Posted: Tue May 29, 2012 10:37 am
Pretty sure 1 liter RnP will be fine. Not 100 percent sure tho
It's the slightest difference. Like I said super low pressures on 31s twin locked n geared n don't even notice it.
Make around tr same difference as a few psi difference in tires.
Post Posted: Tue May 29, 2012 11:00 am
Are fronts high pinion, like coiley Sierras.?
If so, may be no use on fronts?
I must have a crawl under some Jims soon.
Happy to strip one down and post ring n pinion,
whole diff be too heavy and pricey to ship, probably
Post Posted: Tue May 29, 2012 3:07 pm
ALL non-WT maruti R&P's are useless to a jimny owner, as the R&P is too small.
ONLY WT maruti is of any use..... So on numbers alone, you have a better chance of finding a 4.09 jimny 3rd, as they have been in production for 14 years, compared to WT maruti's 3 years.
Post Posted: Tue May 29, 2012 7:48 pm
I have asked Suzistore if the ratio is 4.11 or 4.09... They said they are 4.11 maruti, 1L and jimny...
Post Posted: Tue May 29, 2012 7:59 pm
But:
Jims are 4.09.
Jims are 4.09.
Jims are 4.09.
:lol:
Post Posted: Tue May 29, 2012 8:22 pm
why would they make a ratio.02 different
Post Posted: Tue May 29, 2012 8:25 pm
should have asked them for the tooth count. :wink:
Post Posted: Tue May 29, 2012 8:40 pm
I assume you are referring to cars that have "mismatched" diffs, like early bronco's and F100's that have ford 9" rear diffs and Dana 30/44 front, in which case, the nearest match is 4.11/4.09. Whilst it's true that that taller gears would end up in the front, for the reasons you state, it's not by design, it's an accident of using different gear sets front and rear.
In fact, whilst a taller front diff to rear will assist in steering and climbing, it would be inferior whilst descending, as the rear wheels will drag a little, so directional stability would be worse.
Using radically taller front diff ratios is a mud drag strategy to get the front of the car to "sit up" on the mud and pull straight, but we're talking a very specific use in that instance.
Post Posted: Tue May 29, 2012 8:41 pm
Ask Suzuki, theyre the ones with a short attention span.
Post Posted: Tue May 29, 2012 8:47 pm
The theory was gaining steering by acceleration I think
Post Posted: Tue May 29, 2012 9:01 pm
Overspeeding the front wheels will result in heavy understeer.
Honestly, it's the result of different manufacturers supplying diffs for the same car, not by planning.
Post Posted: Wed May 30, 2012 9:51 am
It's got to do with the physical size of the diff and the amount of torque it's designed to handle.
The 4.09 diff has 11 teeth on the pinion and 45 teeth on the ring gear.
The SMALLER 4.11 has 9 teeth on the pinion and 37 on the ring gear. If the smaller diff was made with 11/45 teeth, the profile of the gear teeth would be too thin even for the torque of a 1.0lt and would shear off teeth. By reducing the number of teeth, the gear sections thicken up, increasing the torque capacity.
So why have the mismatched ratios and not build the bigger diff as a 4.11 too? By scaling up a 9/37 R&P to the dimensions of the 1.3lt diff, the "Coarse" gear sections create proportionally higher drag that actually rob torque, that is they will both handle more torque, but also need more torque to drive them. A "Finer" ratio of 11/45 creates less drag.
Post Posted: Wed May 30, 2012 11:24 am
So, vetting back to the OP.
He has a jimny, which use the large WT sierra sized centres.
Which would be 4.09, or 45/11 teeth.
Am I completely wrong here or what? I swear he's getting the wrong advice here...
Post Posted: Wed May 30, 2012 11:34 am
Only the rear is 1.3 size in a Jimny
I have WT Maruti centers but not for sale :D
Post Posted: Wed May 30, 2012 11:36 am
He has a jimny, which use the large WT sierra sized centres. REAR ONLY
Which would be 4.09 = 45/11 teeth.
Users browsing this forum: No registered users and 75 guests
