It is currently Wed Sep 23, 2026 2:58 am
Vehicle: 96 sierra, 2 inch lift
Post Posted: Thu May 31, 2012 8:14 pm
Hey guys
Just.need some thoughts on what I can do !
My spedometer is out because of my 2inch lift and 30's, a guy I work with says there are devices like a gps that tell you your speed correctly, any ideas on this? Where would I get one.?
Post Posted: Thu May 31, 2012 8:20 pm
Post Posted: Thu May 31, 2012 8:22 pm
^what? :?
Hi, what sort of car and a lift kit won't effect your speedo, because the speedo is mechanically effected, not by height. 30's on a sierra will end up about 9% out (i could be heaps wrong) and i fixed my sierra one with a marks adapters box, others have sent off to get the gear in the actual speedo changed.
TBH, unless you want everything to be perfect, i wouldn't worry about it.
who is going to know?
Post Posted: Thu May 31, 2012 8:23 pm
He's talking about gps as in navigation devices
Vehicle: Suzuki Jimny 2010
Post Posted: Thu May 31, 2012 8:25 pm
mrw82 wrote:
You would have to order a gps from Japan to be compatible with a Japanese made vehicle.
The easiest way to correct the speedo would be to remove the 2" lift and instead fit a body lift.
Lift causes the speedo to be out how???
Post Posted: Thu May 31, 2012 8:27 pm
not sure if serious or just really stoned/drunk :lol:
Post Posted: Thu May 31, 2012 8:28 pm
I think he was taking the piss.
Unsuccessfully.
Vehicle: 1985 Holden Drover
Dont know how on earth that would work but ok...
Mate just get a GPS, much easier :D
1989 WT Sierra.
Post Posted: Thu May 31, 2012 8:31 pm
Unsuccessfully.
That shit pisses me off... funny or not, the guy's tryin to get help!
It must be awesome to know everything huh? (not directed at you Pete)
Post Posted: Thu May 31, 2012 8:33 pm
Yeah was thinking a gps but I didnt think they where very accurate as they only calculate point to point ? Or am I talking shit ?
Post Posted: Thu May 31, 2012 8:42 pm
Most of them ive used have a speedo fuction, refreshes about every second or so. Never had any dramas with speed cameras, just remember to go 5kph just in case ;)
1989 WT Sierra.
GPS is probably more accurate than your 20yr old speedo :wink:
Post Posted: Thu May 31, 2012 8:43 pm
Understood :wink:
Post Posted: Thu May 31, 2012 8:46 pm
ive used an app on my droid smartphone, just search gps speedo, works pretty well, is a bit delayed but only a couple of seconds, so is pretty good. but i just know exactly how far out my speedo is
Post Posted: Thu May 31, 2012 8:48 pm
Yeah no doesn't work so well on my phone as.I just downloaded it and.it was saying I was doing 10km/h and.I wasn't even moving ?
Post Posted: Thu May 31, 2012 8:54 pm
ulysses speedometer is what I use, on a moto defy, not an overly punchy phone, but does the trick, what phone you trying it on?
Post Posted: Fri Jun 01, 2012 4:01 am
Galaxy
Post Posted: Fri Jun 01, 2012 5:36 am
All gps's are about 2 sec out, someone on here posted how to correct odometer reading a couple of days ago. 235/205 + distance travelled.( for 29.5's).You will be able to work out your speedo variation using this formula.
bye
Post Posted: Fri Jun 01, 2012 5:53 am
gps is spot on! works off saelites.....can stand up in court if you have one that keeps the speed you were going at the time!
mine is way way way out! with all the gearin and 32's when im doin 80 on the speedo im doin just under 100.....
get a gps...work out the speeds and use white out on the dash to make a few lines! works wonders!
back in a built sierra!
Vehicle: 93 Sierra 2'' lift 30'' tires
Post Posted: Fri Jun 01, 2012 1:30 pm
My speedo is 10kms slower than the speed I'm doing, I have 30's. Once you know how many km's it's out by, it's easy to get used to. I drive around without even thinkin now, I just know that 60 is actually 70 and 70 is actually 80.. Just borrow a gps, find out how many km's you're out by and keep a note of it in your mind. I even used sticky notes at first just stuck over my speedo glass.
Vehicle: multiple R32's, wtd sierra
Post Posted: Fri Jun 01, 2012 5:33 pm
i found some gauge overlays that had been done for 31 inch tyres but they are in MPH not km/h,
i have put them aside till i can to edit the files to change the measure
Vehicle: '94 suzuki maruti
Post Posted: Sat Jun 02, 2012 7:01 am
my gps reads 94km/h when im actually doing 100km/h... i've tested it in 3 (unmodified) cars. its what ya get when you only pay $40 for it 5 years ago though :lol:
Post Posted: Sat Jun 02, 2012 3:36 pm
Just used the app on my phone in my brothers car is 100% accurate he has a 2012 hilux definitely gonna use it to figure out my speeds on my dash and use a paint pen cheers !!
Post Posted: Sat Jun 02, 2012 5:45 pm
i've found iphone GPS is actually quicker and more accurate most of the time than proper GPS's...
Post Posted: Sat Jun 02, 2012 7:48 pm
whincup wrote:
suzukikid wrote:
gps is spot on! works off satelites...
The GPS will be the accurate speed.
Just because the 3 cars you've tried it in are unmodified doesn't mean they are accurate in showing 100km/h when your actual speed is 100km/h. According to the ADRs covering speedometers (ADR 18/03), your speedo CANNOT show you doing LESS than your actual speed, but CAN show up to 10% + 4km/h HIGHER than your actual speed. Most cars are around 5% from the factory. This amendment to the ADRs was introduced in 2006. Before that, the Speedo could be out by +/- 10%.
If you have a pre-2006 vehicle and take it for an Engineering Certificate for a modification the includes a different tyre size, you MUST correct the speedo accuracy to be within the tolerance in ADR 18/03.
The simplest and easiest way to do this is with a ratio correction box on the speedo cable. The correction box is a quick changeover, and if bought through a decent Instrument Shop then any future changeovers will only cost the price of another set of gears (or even swapped for nix, as they have a large supply of exchange stock for rally vehicles). The initial purchase cost will be equivalent (or less then) the labour charge to have your speedo removed and recalibrated, and the correction box can be removed when you sell the vehicle.
Users browsing this forum: No registered users and 211 guests
