It is currently Wed Aug 05, 2026 3:16 pm
Post Posted: Fri Jun 01, 2012 4:09 pm
Hey guys, how the hell do you get this black thing off the shifter???
MY BUILD THREAD HERE!!!!!
Post Posted: Fri Jun 01, 2012 4:12 pm
Ya don't AFAIK.
Post Posted: Fri Jun 01, 2012 4:13 pm
then how would one replace the boot, spring, etc....
Post Posted: Fri Jun 01, 2012 4:19 pm
Bruce wrote:
Ya don't AFAIK.
Correct they are glued on
Boot stretches over the top from what i remember :?
Post Posted: Fri Jun 01, 2012 4:21 pm
aggggggg
best suggestion for getting it off without destroying it? i need to get the boot and crap off so i can bend it.
Post Posted: Fri Jun 01, 2012 4:22 pm
Grinder. Put a slice down it and pry it off. The boot will slide it off though.
Post Posted: Fri Jun 01, 2012 4:23 pm
It's a tight fit but they come off. Let the rubber invert if that makes sense?
Post Posted: Fri Jun 01, 2012 4:27 pm
well the rubber wont even go past the tiniest little lip on the shaft, its pretty stiff, cant see it stretching AT ALL.
have these been cut off before?
Never cut any of the ones I have taken off.
Post Posted: Fri Jun 01, 2012 4:28 pm
it has to come off somehow or the metal clip and spring cant be replaced ever.
Post Posted: Fri Jun 01, 2012 4:29 pm
are you talking about the rubber? or the solid black thing in the pic?
Post Posted: Fri Jun 01, 2012 4:31 pm
the solid black thing (shifter) is rubber filled & bonded to the shifter shaft for NVH dampening
Post Posted: Fri Jun 01, 2012 4:34 pm
so i cant get it off then. I need to heat the shaft up but im worried about destroying the boot.
Post Posted: Fri Jun 01, 2012 4:37 pm
The boot WILL come off. Pull harder, it won't rip.
Post Posted: Fri Jun 01, 2012 5:16 pm
x2
Post Posted: Fri Jun 01, 2012 5:17 pm
The boot slides over the thick black bit. To replace the spring, you cut the old one off, and slide the new one down over the thick black section. It will take some force. If you aren't sure, try and slide the new one on before you cut the old one off.
The locking collar stays.
Post Posted: Fri Jun 01, 2012 5:19 pm
okay im just leaving it as is for now, im goin crazy on it and i think im just making it worse for later. tried using 3 small screwdrivers to lever it off too. it seems to handle a bit of heat ok, so ill see what happens
Post Posted: Fri Jun 01, 2012 5:32 pm
Turn the boot inside out then pull it offs
Post Posted: Fri Jun 01, 2012 5:38 pm
yeah tried that, its really really really really tight. ill re-visit it tomorrow, im done with it for now. at least the bulk of the t-case swap is done.
Post Posted: Fri Jun 01, 2012 5:48 pm
Soak it in hot water?
Post Posted: Fri Jun 01, 2012 5:57 pm
Try dish washing liquid.
bye
Post Posted: Sat Jun 02, 2012 5:17 am
When I heated mine to bend it after a body lift, I wrapped a wet rag around the hollow part with the rubber insert to stop it burning. This worked ok. I assume you are heating the stick after a B/L??
Vehicle: 1999 Jimny
Post Posted: Sat Jun 02, 2012 5:55 am
Jesus lads, ya wanna squeeze the big black bit through the tiny hole???????? :shocked: Bahahahaha, try KY then :rofl:
Vehicle: '94 suzuki maruti
Post Posted: Sat Jun 02, 2012 6:48 am
i was having a laugh reading this thread :lol: thinking, they need lube... but seriously, try a bit of ky, or vaseline, or something along those lines...
Post Posted: Sat Jun 02, 2012 9:22 am
had another go this morning, the boot aint coming off without destroying it. but its withstanding the blowtorch nicely anyway. so ill just keep at it.
its not for a bodylift, just did an sj case swap.
Post Posted: Sat Jun 02, 2012 9:26 am
NT transfer shifters don't have the rubber in the stick.
May be easier to use one of them.
Post Posted: Sat Jun 02, 2012 9:52 am
I might even have one Scales..
Post Posted: Sat Jun 02, 2012 11:43 am
i used dishwashing liquid to get a new boot on, and cut the old one off
Post Posted: Sat Jun 02, 2012 12:06 pm
well i got it off..... snapped the whole shaft into 3 pieces whilst bending... FUCK!!!!!
Vehicle: Daisy
Post Posted: Sat Jun 02, 2012 10:27 pm
Get the welder out!
How bloody much were you trying to bend the thing?
I bent a gearstick enough to make it work with a BL with a near empty gas bottle, a hammer and a block of wood and had no dramas, you must have been going pretty bloody hard!
Users browsing this forum: Google [Bot] and 242 guests
