It is currently Sat Nov 07, 2026 11:05 am
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2  Next
Post Posted: Wed Jun 06, 2012 3:39 pm
Thought i would start a thread as i cant find the info im looking for.
I have a 2004 jimny with 30" tyres and im going to install a W/T transfer using the Offroad Armoury kit. What I want to know is what sort of reduction will i get with the std W/T transfer.
I was looking at getting some of these gears but idk if they will be ok with the std jimny gearbox and diff ratios.
http://www.lowrangeoffroad.com/index.php/suzuki/samurai/transfer-case/4-16-1-tcase-gears.html
any help would be great.
Post Posted: Wed Jun 06, 2012 5:16 pm
read these.
viewtopic.php?f=5&t=29318&hilit=build+plan
http://auszookers.com/forum/viewtopic.p ... 83&start=0
i like slow rock crawling, so 4.16 ain't low enough for me, but do do a good job on the highway. 4050-4100rpm @ 100kms on 235s.
Post Posted: Wed Jun 06, 2012 6:46 pm
Correct me if i am wrong........
Providing you have 4.09 diff gears and a transfer ratio of 1.32:1 in high and 2.145:1 in low (I believe you do), you will get exactly 6.7% reduction from the case and 5.734% in low from the W/T case. when you get gears just get the 4.16 gears ;) that will give you 19.7 % reduction in high and 93.939% reduction in low, perfect for 31" tyres cos that is 19.2% bigger. 30 is 15.4% bigger than the standard 26" tyres. I have been looking into this exact thing today. :)
Post Posted: Wed Jun 06, 2012 7:05 pm
im not sure if your right or wrong but thats the sorta info im after. guess there would be nothing wrong with getting the 4.16 gears except it might be a bit high in high range
Post Posted: Wed Jun 06, 2012 7:35 pm
There's the option of 4.9's ;)
Post Posted: Wed Jun 06, 2012 8:02 pm
think 4.9 would be to much high range reduction, would be awesome off road tho
Vehicle: Suzuki Jimny 2010
Post Posted: Wed Jun 06, 2012 8:36 pm
Dunno about the %'s for the gears etc, but 30's are 14.07% difference and 31's are 17.79% :)
Post Posted: Wed Jun 06, 2012 9:00 pm
True, i forgot that 205/70 R15 = 26.3 i just did 26 :/
Fixed:
So, here are my calculations for a jim with 4.09 diff gears and a transfer ratio of 1.32:1 in high and 2.145:1 in low.
Correct me if i am wrong again........
TYRE SIZE - PERCENTAGE INCREASE
30" - 14.068%
31" - 17.871%
32" - 21.673%
33" - 25.475%
LOW/HIGH RATIO - RATIO PERCENTAGE INCREASE ("Reduction")
4.16/1.58 - 93.9/19.7%
4.9/1.635 - 128.438/23.864%
5.14/1.667 - 139.627/26.288%
6.4/1.649 - 198.368/24.9%
6.5/1.692 - 203.03/28.182%
Post Posted: Wed Jun 06, 2012 9:04 pm
Put 3.9's in run 4.9's
Post Posted: Wed Jun 06, 2012 9:09 pm
huh?
Post Posted: Wed Jun 06, 2012 9:18 pm
Good luck finding a 3.9 diff gear set that fits in a jimny front................
Post Posted: Wed Jun 06, 2012 9:19 pm
Can't in a Jimny
Post Posted: Wed Jun 06, 2012 9:25 pm
If a jimny locker can be modded to fit a Coily.. Why can't a jimny centre work with Coily gears?
Cut and shut some gear sets.
Look out side the box, or handle the fact you'll have To go 5kms slower on the freeway.
Post Posted: Wed Jun 06, 2012 10:25 pm
You have got me thinking though............ 3.9's would be good with 6.4's and 32"................ more and more mods.
Post Posted: Thu Jun 07, 2012 9:03 am
Good bye CVs.
Post Posted: Thu Jun 07, 2012 5:18 pm
my speedo reads 10kph to slow atm anyway lol. well i think ill just got a set of 4.16 gears and see how it goes.
Post Posted: Thu Jun 07, 2012 8:17 pm
I think 4.16 will be perfect. Highway will be almost perfect and low will be much lower than what you have now.
Post Posted: Thu Jun 07, 2012 8:21 pm
Good bye CVs.
Most defiantly, would have to get some chromo's of some sort sorted :)
Post Posted: Thu Jun 07, 2012 8:55 pm
i pretty much have no reduction, its not fun going down hills!
Post Posted: Fri Jun 08, 2012 12:17 am
There's a pedal in the middle. It slows your car down.
Post Posted: Fri Jun 08, 2012 7:05 am
Jimny front is High Pinion and therefore completely different teeth meshing than rear. It would take some highly sophisticated (and expensive) machinery to make a new R&P, not to mention CAD design.
If it were easy, it would have ben done by now.
Post Posted: Fri Jun 08, 2012 7:08 am
Ok, I may have misunderstood what was being suggested a little. Point remains... Front is High Pinion and hence completely diferent.
Post Posted: Fri Jun 08, 2012 7:32 am
He was talking about using a coily 3.9 front diff center as they are 3.9 and are high pinon mount to.
Post Posted: Fri Jun 08, 2012 10:28 am
I wouldn't have thought it would be done by now because as far as I'm aware only recently have many people been putting Sierra cases in their jimny where you can get big reduction.
If I'm wrong, fine. If not, then you guys have another option to think about.
Post Posted: Fri Jun 08, 2012 10:32 am
I looked into it already....from what fatzook was saying....it wouldn't work
Post Posted: Fri Jun 08, 2012 10:34 am
How come?
Post Posted: Fri Jun 08, 2012 10:51 am
Cant remember of the top of my head and don't have the PMS anymore. Hopefully Pete will chime in...
Post Posted: Sun Jun 10, 2012 1:55 pm
just ordered the 4.16 gears from low range Armsup
Post Posted: Sun Jun 10, 2012 3:35 pm
make sure you get plenty of pics to show us all of the swap!
MY BUILD THREAD HERE!!!!!
Vehicle: 01 jimny
Post Posted: Mon Jun 11, 2012 11:51 am
I used to have series 3 rockhopper gears in my jimny but after destroying them i have installed the trail creeper 6.5:1 gears. I run 31's and find them fantastic. On the highway i sit on just over 4000rpm. The car is mainly used for offroad and the control gained from the gears gives it an awsome ability offroad. It makes it so much safer on those really steep descents you can actually use the accellerator and is great to crawl through rocks with. Look forward to seeing how you get on with your gears.
Users browsing this forum: No registered users and 76 guests
