| Author |
Message |
Red89
Joined: Tue Jan 12, 2010 10:30 pm Posts: 2801 Location: Perth
 Posted: Wed Jun 06, 2012 7:23 pm |
Has anyone got a swaybar, and mounts if possible, still laying around the back of their shed somewhere ? Bearing in mind they tend to be the first thing removed and binned I would think they would go fairly cheaply, not fazed whether its off a Sierra or Jimny just need something to play around with. PM me with what youve got, cheers
_________________ Made in JP. Built in WA.
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Wed Jun 06, 2012 7:33 pm |
I have one in NSW...
_________________ mlm
Joe
Joined: Sat Jul 04, 2009 11:30 pm Posts: 49041 Location: Rockingham W.A
 Posted: Wed Jun 06, 2012 8:07 pm |
Red89 wrote: Has anyone got a swaybar, and mounts if possible, still laying around the back of their shed somewhere ? Bearing in mind they tend to be the first thing removed and binned I would think they would go fairly cheaply, not fazed whether its off a Sierra or Jimny just need something to play around with. PM me with what youve got, cheers  Pretty sure there is one in the shed at my mums ill have a look when i go there tomorrow after work It's a sierra front
_________________ Joe likes boobs ( . )( . ) ( ° )( ° )
Red89
 Posted: Wed Jun 06, 2012 8:41 pm |
Joe wrote: Red89 wrote: Has anyone got a swaybar, and mounts if possible, still laying around the back of their shed somewhere ? Bearing in mind they tend to be the first thing removed and binned I would think they would go fairly cheaply, not fazed whether its off a Sierra or Jimny just need something to play around with. PM me with what youve got, cheers  Pretty sure there is one in the shed at my mums ill have a look when i go there tomorrow after work It's a sierra front
SierraDan
 Posted: Wed Jun 06, 2012 8:51 pm |
Haha if you don't get one. This one is yours for the price of postage.
Red89
 Posted: Wed Jun 06, 2012 9:15 pm |
SierraDan wrote: Haha if you don't get one. This one is yours for the price of postage. Cheers mate
troopy
Joined: Tue Nov 17, 2009 10:30 pm Posts: 398 Location: bunbury
 Posted: Wed Jun 06, 2012 10:25 pm |
I think you will need something a bit heavier than a sierra front I tried one on the rear but it didn't make a noticeable change to stability. The one I use now is from the front of a 4 door swift and the ends are already drilled to accept bolts and heims
Joe
 Posted: Thu Jun 07, 2012 5:01 pm |
No luck from me mate the old lady must of thrown it out in one of her cleaning fits
Red89
 Posted: Thu Jun 07, 2012 5:38 pm |
Cheers for checking anyway Joe For those that pmd me, based on what Troopy has said I might leave this for a week or so, and see what I will get stung by the wreckers for one out of a bigger car.
BlueSuzy
Joined: Sun May 04, 2008 11:30 pm Posts: 9716 Location: NSW
 Posted: Fri Jun 08, 2012 12:40 am |
The 80'series fit nice, Coiled troopys/ute are very similar. But depends on your arm setup
They will be very stiff.
I have a Jim front here if wanted. They are solid unlike sierra ones. Or can give you measurements, easier to work out then
Red89
 Posted: Fri Jun 08, 2012 3:46 pm |
BlueSuzy wrote: The 80'series fit nice, Coiled troopys/ute are very similar. But depends on your arm setup
I have a Jim front here if wanted. They are solid unlike sierra ones. Or can give you measurements, easier to work out then Next time you trip over it can you grab the end to end straight across measurment for me cheers Also does anyone know how long a Vit torsion bar is, and what the spline count is ? I need something around 920mm max. EDIT **** Vit is a spring front end
monley
Joined: Wed Nov 24, 2010 7:58 am Posts: 11092 Location: Mandurah.W.A.
 Posted: Fri Jun 08, 2012 8:33 pm |
I have a jim sway bar here if you want Bevan  PM me if you want it....
_________________ Tell my arse, he actually gives a crap!
alien
Joined: Wed Mar 24, 2010 10:30 pm Posts: 16343 Location: Perth
 Posted: Fri Jun 08, 2012 9:35 pm |
given the weight etc of your buggy, something like a hilux (leafy model) would probably work wouldnt it? (although i know that the standard hilux front is very limited in its travel). Something else to consider would the the old SWB patrols, im sure most of them ditch theirs like us sierra owners.
SierraDan
 Posted: Sat Jun 09, 2012 8:54 am |
VW Beetle torsion bars are about 680mm long. Leyland Marina are supposedly 900mm
BlueSuzy
 Posted: Sat Jun 09, 2012 10:03 am |
Sprintcar torsions are 29" -or- 30"
Red89
 Posted: Sat Jun 09, 2012 4:36 pm |
BlueSuzy wrote: Sprintcar torsions are 29" -or- 30" OOOOHHH hadnt thought of speedway stores. I can get a mix and match new and 2nd torsion bar setup for about $170  All from over east though Had thought about going for a heavier vehicle with the main issue being the room I have to play with, I wanted to mount the ends to the lower links which are around 900mm apart.
troopy
 Posted: Sat Jun 09, 2012 5:25 pm |
I did some measuring of my setup for you and the swaybar is 940mm wide and the swaybar mounts on the chassis are 680mm apart. Since you are mounting the links to the lower arms I would go for a heavier bar and then fine tune it by playing around with where it attaches to the lower arms.
Red89
 Posted: Sat Jun 09, 2012 9:26 pm |
Cheers mate, according to google some Commodore and Falcon ones look promising. I rang up a Laser wrecker yesterday and he said they had the Laser I needed but werent sure if the swaybar even came off as they had never sold one or even removed one before, so even though they are never likely to sell it to anyone else and he suggested I come in and remove it myself he still wanted $150 for it  I wish we still had pick apart over here.
Red89
 Posted: Wed Jun 13, 2012 4:16 pm |
After several hours googling and ebaying over the last few nights I picked up a rear swaybar out of a BA Falcon. The sizing is pretty good I just hope the tension it has is pretty much spot on because if it goes where I want it to there isnt a lot of room for adjustment.
Red89
 Posted: Sun Jul 29, 2012 1:50 pm |
Turns out Troopy was correct and the Falcon one was too stiff, which was a pity because it made the front flex like mad and would have cornered like a race car. I have a 90's swift front one in at the moment, courtesy of suzukishop, which still allows me to max out the airshocks, I havent tested it to see whether its made a difference to handling as I dont have gas in the shocks yet.
Question to those who know. Is the swaybar out of a GTI any thicker, stiffer then the one of of a standard swift ? They look the same shape so swapping one in wouldnt be hard, but I didnt have any verniers on me to check thickness.
alien
 Posted: Sun Jul 29, 2012 5:27 pm |
check the weight between the two - the GTI one might be the same shape/size but solid rather than hollow? (just a thought).
