It is currently Wed Aug 05, 2026 3:07 pm
Post Posted: Thu Jun 14, 2012 8:26 pm
Does anybody know if an lj81 cab will fit onto an lj50 or lj80 chassi ? Will it bolt straight onto the existing body mounts ?
Post Posted: Thu Jun 14, 2012 8:29 pm
Give me a few weeks (hopefully) and I'l be able to measure.
I reckon the back wheel will get in the way of the cab though.
Vehicle: sierra
Post Posted: Thu Jun 14, 2012 9:36 pm
works with an sj40
Post Posted: Thu Jun 14, 2012 9:41 pm
sj40 or sj410 got any pics ?
Vehicle: sierra
Post Posted: Thu Jun 14, 2012 10:23 pm
sj410 was on the plate yes i have pics
83 1ltr tintop
before
after
later on
and its now dead :(
Post Posted: Fri Jun 15, 2012 7:17 am
Thanks for the pics rustyzook. I am thinking of doin the same thing but with an lj. I have found a good cab with minumal rust and i have plenty of swb ljs with rusted out bodies. Was it pretty much a straight swap ?
Post Posted: Fri Jun 15, 2012 1:51 pm
I can measure the mounts on my LJ81 cab if you want. :)
Or you could just send the cab to me! :peaceout: pompoms
Vehicle: sierra
Post Posted: Fri Jun 15, 2012 5:41 pm
just straight on, the rubber was close to the cab, spoa fixed that and moved the diff back a bit, wouldn't do spoa on nt again tho, was scary as fuck
Post Posted: Fri Jun 15, 2012 5:52 pm
If you drew a horizontal line between the front and rear body mounts the distance would be about 850mm. The 2 rear mounts are 1100mm apart. :)
But you should just send the cab to me! :D
Post Posted: Fri Jun 15, 2012 7:09 pm
I reckon it should fit just looking at it. I thought somebody would have to have done it before, was kinda hopeing someone might dig up some pics. I reckon postage to W.A. would be a killer.
Vehicle: sierra
Post Posted: Fri Jun 15, 2012 7:18 pm
i cant see why they would change it as the sj410 are the same with swb and lwb to the mid (swb body) or rear (ute) cab mounts so mine was an easy bolt on
Vehicle: sierra
Post Posted: Fri Jun 15, 2012 7:22 pm
but check wheel clearence! i belted the seams flat on mine !
and because i like to be a pic whore, you could build out own ute, something like the new one in progress
yes i have a 1ltr problem :oops: :deadhorse:
Post Posted: Fri Jun 15, 2012 7:31 pm
Yep. I reckon cab will be close to rear wheels. Hopefull get the cab home this weekend and check it all out then.
Vehicle: sierra
Post Posted: Fri Jun 15, 2012 7:41 pm
you can re drill spring pearches and move diff back, long bumstops and 2" bl will sort it, mine never hit SUA with the 2" bl and 30 but it was like 10mm off spoa and 31's no bl and it would just touch, re drilled perches and never happend again
Post Posted: Fri Jun 15, 2012 7:45 pm
Rustyzook have anymore pics from the side ?
Vehicle: sierra
Post Posted: Fri Jun 15, 2012 7:49 pm
just uploading them now, id love to build a rig based on a swb with ute body bu never spoa again
Post Posted: Fri Jun 15, 2012 8:00 pm
Mine measures 1000mm along the bottom of the sill from the firewall to the end of the sill.
The rear body mount is right at the back of the cab, if your tyres aren't touching the chassis outrigger then you'l be pretty right. :)
I wish I could find a good LJ81 cab!
Vehicle: sierra
Post Posted: Fri Jun 15, 2012 8:03 pm
Users browsing this forum: No registered users and 234 guests
