It is currently Tue Oct 20, 2026 10:11 am
Post Posted: Thu Apr 23, 2009 3:47 pm
Needed for RWC!
air flow through face vents is great.
Airflow to feet is low
Airflow to demist vents along windscreen is even lower.
(Some air reaches there but isn't very strong)
All flaps appear to be working and sealing fine.
Any ideas? Needs to be fixed by tomorrow.
James
Post Posted: Thu Apr 23, 2009 3:58 pm
check your ducting..black platic ducts...they often drop out...
Post Posted: Thu Apr 23, 2009 4:05 pm
Yeah pipes are ok. Checked all of them. I think it is partially blocked between the fan and the heating coil. Is that common and if so how do u clean it without pulling the whole dash apart!
Post Posted: Thu Apr 23, 2009 4:11 pm
so you think that the heater core is blocking the air flow??
Post Posted: Thu Apr 23, 2009 4:36 pm
yes that is what i am thinking. Any ideas how to clean it without pulling dash apart?
Post Posted: Thu Apr 23, 2009 4:52 pm
mmm i guess you could try get an air line in there and blow it out???
Post Posted: Thu Apr 23, 2009 4:57 pm
There is an awesome thread on a site ?outers? on how to clean the core out. I did it on a mates zook, worked a treat!! Basically you find the right spot on the passenger side of the heater box (above where the join mark is for memory?) and you drill out a circle using a hole saw. Then, you get in there with air, a soft brush, vacuum cleaner etc. Once done cleaning the crap out (most likely be leaves and dirt and sand etc), silastic the cap back into the hole. Works a treat!! My mates had no air flow at all.. but once done, it was like a new one :)
F&R ARB air lockers, lux diffs, 4 link coil rear,
Post Posted: Thu Apr 23, 2009 6:10 pm
thanks for that. Thread found
http://www.izook.com/tech/samurai/body/ ... rclean.htm
I will try it tonight.
Users browsing this forum: Google [Bot] and 232 guests
