It is currently Wed Aug 05, 2026 3:30 am
Vehicle: 93 Sierra 2'' lift 30'' tires
Post Posted: Thu Jul 05, 2012 8:59 am
Hey guys I wanna put a second fuel filter in my engine bay, I always have carby troubles and just got everything sorted so I wanna try and keep it that way :) I was just wondering if anyone has pics of how they mounted/set up theirs? I wanna try and do a neat job. Thanks guys :peaceout:
Vehicle: SJ80, SE416
Post Posted: Thu Jul 05, 2012 9:09 am
No pics, but in my daily-drive Sierra I have a Speco brand glass with wire mesh inline filter mounted half way along the carby fuel hose. It is cabletied to the PCV breather hose.
Post Posted: Thu Jul 05, 2012 10:27 am
What ended up being the problem with your carbie Josh?
Post Posted: Thu Jul 05, 2012 1:18 pm
It just had shit in it... And a lot of components didn't work, so I got a reconditioned one and that 100 percent fixed the problem! Very happy customer :D
Post Posted: Thu Jul 05, 2012 1:26 pm
But didn't they put on a recon carbie on and it still played up a few days later? Shit in your fuel lines?
I was checkin your out the other day it looks good with the new tyres & rims :D
Post Posted: Thu Jul 05, 2012 1:43 pm
ohhh yeah, shit got in the carby again.. did the old swap the leads trick and that worked. havent had a problem since and that was 2 weeks ago :D so im just doing everything i can to prevent things happening again.
yeah cheers mate shes come up good :) needs ruf and gearing and she'll be all set!
Post Posted: Thu Jul 05, 2012 2:21 pm
thanks mate ill have a look and see if i can figure out where it should go :)
Vehicle: Clown Car..
Post Posted: Thu Jul 05, 2012 5:59 pm
Post Posted: Thu Jul 05, 2012 6:04 pm
foolsp33d wrote:
Awesome mate thanks heaps that's exactly what I was looking for :) can I ask what sort of filter is that and where did you get it from? I wanna get one tonight :) thanks!
Post Posted: Thu Jul 05, 2012 6:10 pm
it's just a low pressure plastic fuel filter with straight barbs on it, any auto shop will be able to help
Post Posted: Thu Jul 05, 2012 6:23 pm
Awesome - thanks. This may be a stupid question but will it affect the fuel getting into the carby? When starting and stuff
Post Posted: Thu Jul 05, 2012 6:27 pm
nope, it will be fine. :wink:
Post Posted: Thu Jul 05, 2012 6:49 pm
Cheers matee :D
Post Posted: Thu Jul 05, 2012 6:59 pm
Those exact filters you can get at SuperCrap for $3. Their good because you can tell what shits in them and if there's any water in your juice
Vehicle: 1.6 SJ80
Post Posted: Thu Jul 05, 2012 7:07 pm
I would run one of these before your factory filter as the filtration won't be fine enough. Put it somewhere that you can get at and out of the way. Alot of diesels run a CAV filter with a water seperator which work well, not sure if they are only for diesels?
Post Posted: Thu Jul 05, 2012 7:18 pm
I think the point of having it in the engine bay is to stop crap from the fuel pump membrane getting through or something?
Vehicle: 85 hightop drover
Post Posted: Thu Jul 05, 2012 8:12 pm
Bingo :D
16valve efi hightop drover
Post Posted: Thu Jul 05, 2012 9:29 pm
I also replaced the stock filter with an inline efi filter,
got it for $30 brand new, think was from a commodore?
They filter better, and last a very long time
Post Posted: Thu Jul 05, 2012 9:33 pm
Personally I wouldn't keep a large volume filter above the engine - I'd be worried about boiling the fuel but then again i'm not a mechanic.
I have this one and it's a fraction of the volume and re-usable as well.
If you are worried about price, repco sell these Ryco Z676 'tiny' ones for less than $10 and they don't occupy much more space than the hose itself and you could put one on the carby end of the hose and not have to tie it down...
http://www.rycofilters.com.au/library/news/1235626035_document_77-09_e-notice_feb_web.pdf
I'd use the Ryco ones next-time and just replace it every so often.
Post Posted: Thu Jul 05, 2012 11:02 pm
That's awesome thanks mate! Went to super cheap they were out of stock so it must be a sign that I should get that one haha cheers!
Post Posted: Sat Jul 07, 2012 7:51 pm
Would these filters, with a water seperator, be any benefit in a petrol engine? I know they are very common mods for diesels but haven't heard of them being used in petrols?
2002 SWB GV
Lifted and Locked
Vehicle: 1.6 SJ80
Post Posted: Sat Aug 11, 2012 7:43 pm
I have been doing abit of research around this filtration for petrols and have found that a Lucas/Delphi HDF296 CAV filter will work on petrol. They have a filtration rating of 6microns and a flow rate of 45L/hr. You can buy a pack of 10 from ebay for about $25 Armsup
There are a few people running them on carbi, efi seems abit more complicated. I will have abit more of a read before I suggest anyone with an efi to run them....
Post Posted: Sun Aug 12, 2012 8:42 am
No point having a water seperator filter in a petrol vehicle... Just add a litre of metho to the tank every few months..
Metho is hygroscopic so it absorbs the water. Metho mixes with petrol and gets burnt.
Metho doesn't mix with diesel so you can't use it and need a proper water seperator filter.
Post Posted: Sun Aug 12, 2012 10:08 am
What are the issues with EFI? Is it the fuel pressure or flow rate???
Post Posted: Sun Aug 12, 2012 11:03 am
EFI requires a high pressure filter. usually a metal one, for christ sakes if you have EFI, DO NOT put a $3 placcy one from supercheap in.
it WILL rupture, and you will have a lovely engine fire to deal with!!!!!
remember EFI fuel pressures are around 60psi, so even the hoses you need to be carefull with!
MY BUILD THREAD HERE!!!!!
Post Posted: Sun Aug 12, 2012 11:18 am
Last "Metho" i bought was named 100% ethanol on the back
Not sure if they still make the old style
Vehicle: 1.6 SJ80
Post Posted: Sun Aug 12, 2012 11:51 am
Yes it is the fuel pressure that does it apparantly. 60psi is efi however most supply pressure for common rail is above 100psi and the new lift king that arrived at work is common rail and has a cav type filter.
Want33s I would be getting a cav type filter for the filter price and ease of replacement.
Flow rate should be fine EFI
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 979 guests
