It is currently Sat Nov 07, 2026 2:58 am
Vehicle: suzuki sierra sj80
Post Posted: Mon Apr 11, 2011 1:46 am
hey guys few weeks back i noticed i was leaking oil outta the rear of trasnfer case on my suzuki seirra 94 model how hard is it to change the rear seal cheers
Vehicle: 2018 DMAX
Post Posted: Mon Apr 11, 2011 1:57 am
If its the output seal your talking about, Remove tailshaft from transfer, remove flange from transfer, remove seal, new seal and stick everthing back together... The flange will be a bastard to undo...
Post Posted: Mon Apr 11, 2011 2:05 am
ok sweet yeh its the output shaft seal thank mate
Post Posted: Mon Apr 11, 2011 2:15 am
i had a look at my flange on the end of the shaft coming out of the transfer case how do u remove it ?? its got alot of crap on it lol cheers
Post Posted: Mon Apr 11, 2011 2:16 am
Post Posted: Mon Apr 11, 2011 2:29 am
You need to take off the four bolts (14 mm socket/spanner?) to drop the tailsahft.
Once that's out you'll see a big nut (26mm?) in the centre of the flange. Getting that flange nut off is a big challenge. If the case is still in the car it maybe easier... Put the car in 4wd and in gear and it should stop the flange from spinning whilst you turn the nut. It make take some serious effort to shift that nut though.
Once the nut is out the flange just slides off and you'll see the seal behind it. Prise the old seal out and stick the new one in, and then put everything back together again!
I want my old sig back :(
Post Posted: Mon Apr 11, 2011 3:32 am
ok thanks heaps mate ill get into it this weekend cheers
Vehicle: Daisy
Post Posted: Mon Apr 11, 2011 7:00 am
You may need to get a genuine seal though, I know mine is still leaking with an aftermarket one...
Post Posted: Mon Apr 11, 2011 7:31 am
I got mine from Bursons perfect size.
Vehicle: Daisy
Post Posted: Mon Apr 11, 2011 10:47 am
A Genuine one? I just got one from the bearing shop which when I got home looked identical to the one that came in the lowrange offroad kit.
Also, it leaks...
Vehicle: 2018 DMAX
Post Posted: Mon Apr 11, 2011 10:54 am
Also, it leaks...
Im useing the lowrange one and havent had an issue.. Just make sure everything is clean when it goes together... My gearbox output leaks due to damage to the mounting surface caused by someone trying to pry the seal out, mite be an issue with your transfer..
Post Posted: Mon Apr 11, 2011 11:30 am
No idea. Doesn't leak but.
Vehicle: Daisy
Post Posted: Mon Apr 11, 2011 7:48 pm
boostedbrick wrote:
Also, it leaks...
Nah, it's mint, the seal was super easy to push in though, just got to find a genuine one.
Vehicle: Coily "Ute"
Post Posted: Mon Jul 16, 2012 12:21 pm
i need to do this. what am I asking for at bursons? whats the chances you have a part number for it?
Users browsing this forum: Google [Bot] and 330 guests
