It is currently Tue Oct 20, 2026 11:49 am
Post Posted: Wed May 06, 2009 12:11 am
When in mud I am continually getting hung up on my spring plates and i think that it is mostly because of how sharp they are, not rounded edges and the bolts dig straight in aswell. I saw this on Outers:
and thought it was a great idea. Anyone know if these are made by anyone for sierra's? I realise you would have to relocate the bottom shock mount but that is nothing too big, anything else that would stop this from being run on a sierra?
Thanks
Post Posted: Wed May 06, 2009 12:26 am
I dont think it is as much of a prob as you think but calmini or trail tough make a skid spring plate, different to that but same effect
that setup you would want to be confident that the design and welds are up to scratch
Post Posted: Wed May 06, 2009 12:32 am
yeah i suppose, just need more hieght over the diff. I need bigger tyres but i thought this could be a potential answer
Post Posted: Wed May 06, 2009 12:34 am
SPOA
navara on 33s. hopfully rear air locker soon
Post Posted: Wed May 06, 2009 12:38 am
a legal option.....
Post Posted: Wed May 06, 2009 1:26 am
it is where i live 8)
Post Posted: Wed May 06, 2009 2:07 am
Cut the U bolts off level with the bottom of the nuts and shave the diff. Will get you and extra inch & a bit of ground clearance.
BUT if you are constantly getting hung up on the spring plates.... You need bigger tyres.
Jas.
Post Posted: Wed May 06, 2009 2:12 pm
And even if your welds are good you still have a heat affected zone. I'd be much more comfortable with that bottom plate being made from 1 piece of material. You should be able to get something like that press bent.
Post Posted: Wed May 06, 2009 3:27 pm
this is what i have, haven't been hung up on them yet.
Post Posted: Wed May 06, 2009 6:09 pm
be thankfull you dont have a set of arms under your diffs.....
Post Posted: Wed May 06, 2009 8:03 pm
why??? did you run over someone.
Users browsing this forum: Google [Bot] and 146 guests
