It is currently Tue Oct 20, 2026 10:50 am
Post Posted: Sun May 10, 2009 11:16 pm
hey guys i have a 85 swb sierra soft top and the rear springs have more leafs then the front and sits lil higher i was wondering if i can rotate the leef springs around put front in rear and rear in front?? then i should get a level ride and their would be more spring to suport the weight of the motor?? whats ur ideas??
Vehicle: MY2019 Jimny
Post Posted: Sun May 10, 2009 11:17 pm
They are different lengths...
Post Posted: Sun May 10, 2009 11:32 pm
the other problem (and lots forget this when looking at RUF) is the longer rear springs are a lot softer, even though they have more leafs
Post Posted: Mon May 11, 2009 12:00 am
surely the lenth wouldnt be that diffrent and the shackle would allow for the difference
lol
Post Posted: Mon May 11, 2009 12:05 am
about 100mm IIRC
Post Posted: Mon May 11, 2009 12:17 am
sooo would it be posable?
Post Posted: Mon May 11, 2009 12:18 am
What are you trying to achieve?
Yes, putting rear springs up front can be a good thing (when set up properly), however swapping front for back will not work.
Post Posted: Mon May 11, 2009 12:23 am
y wont it what will it do?
Post Posted: Mon May 11, 2009 12:26 am
they are too short
they are too stiff
they are too flat
the locating pin is wrong
so you will have a rear end that bounces like a wheelbarrow, jams the tyres into teh wheel arches and scares the crap out of you every time the shackles invert
Post Posted: Mon May 11, 2009 12:31 am
hahah awsome
well can i take the load leaf out to giv it a softer feeling?
cheers for your help ay
Post Posted: Mon May 11, 2009 12:59 am
When you put your rear springs up front (RUF), you need to relocate the spring hanger.
Same for putting the fronts out back (FOB), relocation is needed.
Try taking out one of the longer leafs, they will affect it more.
Post Posted: Mon May 11, 2009 1:31 am
ok kewl so u think maybe the middle leaf. .
Post Posted: Mon May 11, 2009 2:03 am
yeah 3rd one down.
Users browsing this forum: No registered users and 166 guests
