It is currently Fri Nov 06, 2026 10:29 pm
Vehicle: 1985 lwb sierra UTE
Post Posted: Mon Aug 13, 2012 1:02 pm
The jimny pitman arm is way shorter than the sierra 1,i picked up my power steering today and i was gob smaked it looks like it will work realy well with my RUF plans and i also orded some fancy renfourcing plates for the front of my chassis that kinda cap around the chassis all the way to the out riggers and around them it will look awsome once there glued on (will look very very factory like ) :)
Post Posted: Mon Aug 13, 2012 1:21 pm
Define "way shorter". As for the rest of your post I have no idea what you are on about..... :?
Post Posted: Mon Aug 13, 2012 1:31 pm
about 30mm
Post Posted: Mon Aug 13, 2012 1:34 pm
do you think the 30mm shorter pitman arm have any effect on steering? :?
Post Posted: Mon Aug 13, 2012 1:50 pm
my IFS pitman arm on the LJ is about 50mm longer
relevance? bout as much as the rest of this thread
Post Posted: Mon Aug 13, 2012 1:52 pm
w0w 50mm tanshi, does the extra length get the bitches? :lol:
Post Posted: Mon Aug 13, 2012 1:54 pm
yep, works along side my pod filter and glow in the dark valve caps to get them all steamy
Post Posted: Mon Aug 13, 2012 1:56 pm
i bet teh valve caps makes them moist especially when doing mainies.
Post Posted: Mon Aug 13, 2012 2:36 pm
well i shed some light on it for yas then u can take the piss all day long :)
#1 im doing a ruf ,
#2 the diff moves foward 25ish mm
#3 the steering arms are know to rub
#4 wanted power steer so my wife will drive the zuk
#5 the steering arm is shorter and will give me the clearence i need for my drag link and such.
and as far as i know a jimny steers ok and power steer will change it dramaticaly any how trial and error will happen but the research iv done so far proves this to work but hey who knows it may go belly up we will see...
im also using coily bumpstops so there is a danger there using anything coily :shocked:
from Ken
Post Posted: Mon Aug 13, 2012 2:40 pm
vitara on is also shorter but not so short as to effect the steering lock which the jimny one might.
i believe they will fit the same spline.
Post Posted: Mon Aug 13, 2012 3:02 pm
awsome if i get into trouble ill check it out thanks
Post Posted: Mon Aug 13, 2012 5:23 pm
The spline is different.
It does not affect lock, just the amount of turns lock to lock.
Post Posted: Mon Aug 13, 2012 5:28 pm
really? I've fitted a vitara drop pitman arm to a jimny power steer box. :?
Post Posted: Mon Aug 13, 2012 6:24 pm
Nah Pete what I am saying is you cant achieve what he is chasing with just a vitara or jimny arm you need the whole steering box the spline is different to sierra
Post Posted: Mon Aug 13, 2012 6:26 pm
2stroker, i'm guessing he has the Jimny box to go with the Jimny pitman arm
Post Posted: Mon Aug 13, 2012 6:28 pm
Magic!
Post Posted: Mon Aug 13, 2012 6:59 pm
I know what u guys are saying ,some sierra s came out with power steer as well maybe that's were the mix up is :)
Post Posted: Mon Aug 13, 2012 7:20 pm
Hurry up and put it in
From Tim
Bye
Post Posted: Mon Aug 13, 2012 7:33 pm
He he still a ways off ,iv got heaps of work ahead
Post Posted: Wed Aug 15, 2012 6:23 am
This is the tech section...
I see no info here that shouldn't be in a build thread...
Post Posted: Wed Aug 15, 2012 6:04 pm
I would start a build thread but I’m not comfortable to put my work or ideas out there. Also I’m not Shure how to, or if peeps want to even know about it, also I thought this was just the gen post area I’ve only been around auszookers for a while so I’m still trying to nut it all out. Hence why you guys are getting the shits with me. I can’t talk to any one I really know about zooks "they couldn’t care less" u guys love zooks as do I. Yes I’m new to zooks but I’m not stupid or to stuck up, but I’m experienced in basic fabrication and basic general engineering and automotive. I just love reading and chatting about zooks I’m doing a build at the moment that’s taking way way too much time but I have to be patient.
Half the time I don’t know if peeps are taking the piss or joking as it all how u read the text at the time, but hey I’m here still and willing to learn I just hope I don’t drive u all crazy in the proses lol
Users browsing this forum: DesmondTheDrover and 102 guests
