It is currently Thu Jul 23, 2026 9:43 am
Post Posted: Thu May 14, 2009 12:08 am
i have the 1.6ltr carby engine in my sierra. would i have to get a clutch to suit a 1.6 or 1.3??
stupid question maybe?
cheers
brad
Post Posted: Thu May 14, 2009 12:16 am
what gearbox?. clutch type is determined by gearbox.
Post Posted: Thu May 14, 2009 12:17 am
if you have a sierra gear box i would say 1.3 clutch. pull it apart and have a
look though as there are two clutches for the 1.3.
cheers
brad
The transmission you have will dictate what clutch you have. Most 1.3->1.6 engine swaps utilise the original transmission, so it's most likely that you'll want the 1.3 clutch. I'd recommend pulling your clutch out before you buy one though, as there are 2 differnt types of clutch plate for the 1.3s, (the spline count is different).
Post Posted: Thu May 14, 2009 12:24 am
thanks heaps for all that. is it hard to pull the clutch out? considering you could hold the gearbox in one hand i dont think i should have too much trouble hahaha.
Post Posted: Thu May 14, 2009 12:34 am
i am doing it tomorrow so i can take some photos if you want.
it is a 1.6 with sierra box as well :wink:
Post Posted: Thu May 14, 2009 12:41 am
that sounds good shep. much appreciated. how does your mighty 1.6 go? i am a bit worried about mine will have to take it on a non member run to compare.
Post Posted: Thu May 14, 2009 1:11 am
haven't had a chance to test it out yet, i drove it around the block and broke a clutch cable. http://www.auszookers.com/index.php?nam ... pic&t=4799
Post Posted: Thu May 14, 2009 1:38 am
or 3 :D
Can someone tell me which ones take the stepped flywheel and which ones use the flat ones? I thought flat were NT and stepped WT but could be wrong? Sorry for the threadjack :oops:
Post Posted: Thu May 14, 2009 2:36 am
i have 3 gear boxes 89wt swb, 85 drover pos, 85 1.3 lwb all of them have 20 spline
input shafts and used a stepped flywheel. my wt is still a sj50 so maybe it is
the sj70's that are different.
Post Posted: Thu May 14, 2009 2:38 am
or maybe it was the vit flywheel that was stepped and what i have is flat :lol:
i will have a look in the morning
Vehicle: '92 Sierra
Post Posted: Thu May 14, 2009 1:02 pm
or 3 :D
Your best bet is to pull it out and check. I was "told" by both repco and autobarn mine was the early one with the lesser numberd spline (19?) and the flat flywheel then when I pulled it apart it was the complete opposite. Needless to say I now have an expensive paperweight of a new 19 pressure plate and clutch.
To the OP I've got the exact same setup as you. Notch a v out of the front of the transmission mount (forward of the centre bolt hole). Once that's done its pretty damn easy to muscle the box in and out. I've had mine in and out half a dozen times now. Plus you'll be happy with the 1.6 performance over the 1.3 though I've added EFI to mine now.
Post Posted: Thu May 14, 2009 1:18 pm
all NT are one type
WT are a choice of 2, different splines and stepped or flat flywheel, have to use the right flywheel to suit your box too
Coily are all the same, so you might be able to go with that, assuming it hasnt been changed
Post Posted: Thu May 14, 2009 1:40 pm
So stepped use the 22 spline?
And flat use the 19?
Post Posted: Thu May 14, 2009 4:15 pm
With a coily, they use the same clutch and pressure plate as a 20 spline leaf model. The throw out bearing is different though.
Post Posted: Thu May 14, 2009 6:36 pm
just to throw a spanner in the works, these are the two sierra clutches that i have. the new one has 18 spline, the old has 20.
my car 89 wt sj50 has the 20spline and a stepped flywheel :D
Vehicle: MY2019 Jimny
Post Posted: Thu May 14, 2009 7:30 pm
Mine only has one... :wink:
Post Posted: Thu May 14, 2009 8:07 pm
i have one of those rare triple plate hi-tec jobbies. :D
do you want the POS it just brakes clutch cables.
lesspostingmorewheeling
Post Posted: Thu May 14, 2009 9:17 pm
i will take the clutch if your giving it away :wink:
Users browsing this forum: Google [Bot] and 56 guests
