It is currently Fri Nov 06, 2026 10:29 pm
Post Posted: Wed Aug 15, 2012 7:25 am
Hey guys just wondering if this can be done? I have a NT. sierra and i want to swap to WT diffs, and i have the vit diff in the shed. i think i read somewhere that the vitara. rear is the same width as a WT. Is there any problems apart from spring mounts i will encounter??
Can the rear drum backing plates be swapped?
Cheers.
Donny.
Post Posted: Wed Aug 15, 2012 8:19 am
They are wider than WT sierra, a little bit wider than hilux. There will be one major problem, the vitara diff centre is slightly offset to the left whereas the sierra diffs are offset to the right. Much easier to find another WT sierra diff IMHO.
Post Posted: Wed Aug 15, 2012 11:34 am
X2. Unless you are shortening the housing, they are all wrong for sierra.
Post Posted: Wed Aug 15, 2012 3:26 pm
Time to hunt around for a rear WT diff then.
Vehicle: 1985 lwb sierra UTE
Post Posted: Wed Aug 15, 2012 4:48 pm
wow thats good tech to know :beer:
Users browsing this forum: DesmondTheDrover and 99 guests
