It is currently Tue Oct 27, 2026 12:50 am
Vehicle: 07 jimny
Post Posted: Thu Aug 30, 2012 10:07 pm
well its starting again, since i put extractors on my jimny, every now and then the engine warning light comes on,
soon as i hook the jimny to the computer it says o2 senser problem..
ive tried 3 different sensors, changing the sensor position in the extractor, deeping the sensor in the extractor
but still engine warning light comes on..
it goes into limp mode and uses twice as much petrol
anyone had same problem or have any ideas ??????
Post Posted: Thu Aug 30, 2012 10:37 pm
Sure it hasn't got an exhaust leak upstream of the O2 sensor?
Vehicle: 07 jimny
Post Posted: Thu Aug 30, 2012 10:40 pm
had it checked and muffler place said no leak,
it can go 3 or 4 months and good then it will come on 3 or 4 times over a few days until i wipe the computer
normally lasts another 3 or 4 months
Vehicle: Suzuki Jimny 2010
Post Posted: Fri Aug 31, 2012 5:22 am
What model jimny?
Post Posted: Fri Aug 31, 2012 5:36 am
Is the sensor angled down a little to prevent condensation building up on it?
Post Posted: Fri Aug 31, 2012 6:05 am
Depending on what model jimny, there could also be 2 O2 sensors, one on the extractors and another down near the cat
Vehicle: lj81 stockman
Post Posted: Fri Aug 31, 2012 6:08 am
Could it be caused by some other sencers, I no with some cars coolant temp sencers will throw o2 dtc
Vehicle: 07 jimny
Post Posted: Fri Aug 31, 2012 8:43 am
cheers guys but no second sensor, im not sure about angle or temp sensor but i will look into those ideas
Post Posted: Fri Aug 31, 2012 9:12 am
Space the sensor off from the extractor should stop it.
Iv had a similar problem after putting a larger more free flowing exhaust in my Lancer. the problem was cause of the new exhaust the gas amount was increased going over what the sensor was set up to see, spacing it off reduces the amount that the sensor sees so you can get it back to what it use to be
if that doesn't work then no idea. but its worth a try
Vehicle: 07 jimny
Post Posted: Fri Aug 31, 2012 6:58 pm
i talked with ontrack 4wd and the sensor .. it had been spaced out.. didnt work
Post Posted: Fri Aug 31, 2012 9:13 pm
monley had a similar problem with his M13 Jimny & extractors, something to do with a lack of an egr pipe on the headers. :?
Post Posted: Sat Sep 01, 2012 12:05 am
not 100% on this as I dont have extractors or this problem but...
if you look at the extractors suzi store offer http://www.suzistore.com.au/shopexd.asp?id=1857 <<< there
you will see a small pipe coming from the exhaust manna-fold out of pot no. 4
pretty sure this is the EGR and the cause of your problems as (I think) in your case it doesn't exist.
I would check that with someone else before doing anything though.
Post Posted: Sat Sep 01, 2012 12:22 am
thats what i was thinking Ben, here is a set with the EGR pipe fitted.
Vehicle: 07 jimny
Post Posted: Sat Sep 01, 2012 11:31 am
mine has the EGR pipe on my extractors aswell
Post Posted: Sat Sep 01, 2012 12:56 pm
haha that's probably not your problem then.
sorry I couldn't help
good luck
Post Posted: Sat Sep 01, 2012 4:10 pm
what are you using to get the o2 code? is it possible you are mis-diagnosing the check fault? have you done the paperclip trick to get the light to flash the code?
MY BUILD THREAD HERE!!!!!
Post Posted: Sat Sep 01, 2012 6:43 pm
This sounds like a similar problem I'm having at the moment, because mine is throwing out the check engine light and chewing a shit load of fuel and is a bit sluggish. Need to get someone to check the code to fix them problem soon.
Vehicle: SWB Sierra
Post Posted: Sat Sep 01, 2012 7:14 pm
Do Jimmy's have a single wire sensor?
Perhaps the sensor is borderline too far from the engine to heat up properly.
Post Posted: Sat Sep 01, 2012 10:03 pm
looks like a 4 wire in that pic i posted.
Vehicle: SWB Sierra
Post Posted: Sat Sep 01, 2012 10:38 pm
:oops: probably should have looked at that photo more closely, if it's a heated sensor that won't be the problem.
Vehicle: 07 jimny
Post Posted: Tue Oct 22, 2013 7:38 pm
long time not made a post but have some info you might be interested in,
after about a year or more of o2 sensor problems to do with my extractors... changing sensors, moving the sensor, putting it on a dyno
the engine warning light coming on when I use 95 or shit petrol
I found a 02 sensor eliminator
http://www.magnumtuning.com/en/detail/a ... zuki/jimny
its been a month now and no warning light.. will keep u up to date
Vehicle: 2005 Jimny VVT
Post Posted: Tue Jul 29, 2014 11:06 am
Not sure if it is totally frowned upon to resurrect an old thread like this, was just wondering if you could comment on the installation of this beastie?
I'm having almost exactly the same troubles as you; I stumbled on that product last night and it's looking like the go but I have no idea if I could manage the install myself - where did you splice it in?
Vehicle: 07 jimny
Post Posted: Tue Jul 29, 2014 2:40 pm
Hi Darkness, resurrect if it helps.. well I had a mate who installs car stereos wire mine for me, he looked at the diagram they give and wired it in in about 6 minutes, I think any auto electrics guy would do it for you just as quick..
it works a treat, when I took it to Suzuki and put it on the computer after fitting, showed all codes perfect, ECU always gets perfect signal
ive never had an red engine light on in the dash since I fitted it.. Jimny has run like new
Vehicle: jimny g13bb, 99 wrx!
Post Posted: Tue Jul 29, 2014 6:26 pm
Injectors all ok? Not throwing too little or too much fuel in? Also maf sensor not having troubles? Just taking a crack that maybe fuel or air mixture is too lean or rich causing the o2 to play games?
Post Posted: Tue Jul 29, 2014 7:38 pm
I only wish I knew how to check, Cal. My OBD2 diagnostic from the jimny seems to give me a lot less info than most other cars i've tried it on. Doesn't smell rich, mileage is as expected if I drive like a grandma but chaotically abysmal if I rev out every gear and go foot to the floor all the time.
Post Posted: Tue Jul 29, 2014 8:45 pm
The problem that you will get with the eliminator is that the ECU won't self-tune so it will go out of tune as it wears. You don;t have a MAF so it won't be that, what do your fuel trims look like? if you can plot the diagnostics then check how long it takes for the O2 to hit closed-loop, that will give you an indication of how well the heater is working. With the engine fully warmed and from start-up it should hit closed-loop in around 25seconds.
The later Jimnys support EOBD but to get all the information from the ECU you need a Suzuki scan tool that can access the 'OBD1' datastream.
Vehicle: XL-7 (gone) + Kizashi
Post Posted: Tue Jul 29, 2014 9:38 pm
Perhaps the problem is the O2 sensor isn't mounted on the correct angle? Have a read of this http://wbo2.com/lsu/lsuinstal.pdf - it's hard to tell from the previous extractor picture if the sensor is mounted horizontally (ie. incorrectly) or the sensor tip has the required downwards angle?
It could also be worthwhile checking the sensor earthed is okay. It should be earthed through one of the wires (being a 4 wire sensor), but you never know. (I had problems on a single wire O2 sensor after fitting extractors due to the sensor no longer being adequately earthed.)
Users browsing this forum: No registered users and 302 guests
