It is currently Fri Jul 17, 2026 5:05 pm
Vehicle: 85 LWB sierra
Post Posted: Sat Sep 01, 2012 10:02 am
Need one or the other of the above to suit a SJ seirra. basically snapped a front axel and i really want my stockman back on the road.
any help would be much appriciated.
im located in SA but would be willing to pay for freight from almost anywhere.
thanks
Vehicle: sierra
Post Posted: Sat Sep 01, 2012 12:45 pm
1ltr or 1.3
Post Posted: Sun Sep 02, 2012 10:40 am
Was originally a 1L is there a difference?
Vehicle: 1985 lwb 1.3 nt sierra
Post Posted: Sun Sep 02, 2012 4:07 pm
Im taking the axles off my lwb 85 narrowtrack soon to put widetracks on,im in perth wa. need both or just front?
Post Posted: Sun Sep 02, 2012 10:24 pm
Can you fit wide track axels to narrow track?
Um just fronts but I'd buy all for spares depending on price, pm me.
Post Posted: Mon Sep 03, 2012 12:11 pm
With some cut and weld you can get widetrack onto narrows,different spring perches and different diff ratios
Post Posted: Mon Sep 03, 2012 12:45 pm
So could I theoretically get the chromoly wt axle kit of low range and mod it to suit?
Vehicle: 91 swb vit 5"lift 31's.
Post Posted: Mon Sep 03, 2012 4:52 pm
if your still chasing some i have a set here of mubbys at my house i can ask if he wants to get rid of them.. pm me if you need some :)
Post Posted: Mon Sep 03, 2012 9:13 pm
Yes you definitely could,thats what im doing. With a quick weld to remount spring perches its almost bolt on. just decide if you want the longer gearing of the wt diffs first ;) can always change the centres anyway.
Post Posted: Tue Sep 04, 2012 12:03 pm
There is a bit more to it than that, those perches have to mounted in the right position to achieve the right pinion angle, cutting off the old ones is not that easy if you want to reuse them, otherwise you need to buy some mounts or cut them from another housing where you can cut the housing to waste and get them off neatly.
If you want to go chromo you need to fit a complete WT diff housings to the ront, upgrade to 26 spline front centre, fit a complete WT diff in rear as well, change tailshafts from 1 Litre to WT, change flanges on transfer to take the WT shafts, change steering arms to WT, lengthen front brake lines. As already mentioned by someone your diff ratios are also different.
Dont get confused between people talking about axles as compared to talking about housings. If you have a 1 litre front diff it has a smaller diff centre and housing tube size, you can either use 1 litre axles and cv's or you can upgrade and use 1300NT axles and cv's in your current diff housing.
Post Posted: Tue Sep 04, 2012 12:56 pm
Ah didnt realise his was 1lt. Mine is 1.3 and i have a donor wreck (wt swb) for steering and suspension parts. Didnt know the perches were that hard to remove though,il get some new ones through work i think.
Users browsing this forum: No registered users and 18 guests
