It is currently Tue Aug 04, 2026 10:52 pm
Post Posted: Wed Sep 05, 2012 8:30 pm
hi all just wonting to do a coil conwersion in the rear on my drover just wonting linke to people builds lots of pix and springs and shocks used thanks alot to all that contribute :D
Vehicle: LJ20 LJ50
Post Posted: Wed Sep 05, 2012 8:35 pm
heaps of info in this link coil conversion pics here
Post Posted: Wed Sep 05, 2012 9:03 pm
What is your reason for wanting a coil rear? What sort of link setup do you want? Radius arm? 3-link A-frame? 4 link? 3-link + panhard? Will the car be road driven? How much travel are you after? Will you be coiling the front? What sort of terrain do you drive on? What sort of fabrication/welding experience do you have?
Doing a coil conversion is a BIG job and alot of things need to be taken into consideration before you even think about going near the car with a grinder....
Take a look through the rigs section to give you some idea on what is involved in doing a coil conversion.
viewtopic.php?f=4&t=30877&start=300
viewtopic.php?f=4&t=13839
viewtopic.php?f=4&t=2072&start=420
Post Posted: Wed Sep 05, 2012 9:25 pm
ok the car wont be driven on the road reson is i wont more flex i have spring ove in it now but its to high and unstable so lover and more flex is the aim i was thinking 4 link looks like a easyer and affective setup terain is large hills and lots of large rocks and rutts and i will do the front later on due to money resons welding and fab exp not alot traly i can weld ok get good penertration and strenth just looking at 33 for now but 37's later on and extend the wheel base abit. thanks for the help to i have been looking into it for a while.
Post Posted: Wed Sep 05, 2012 9:31 pm
just trawl the forums for a while to get a feel of what people are doing. i would seriously suggest a good 3 months of solid reading and researching.
checkout zukikrawlers.com and pirate.com and here obviously and research research research! its always better to read more than you have to than not enough.
Post Posted: Wed Sep 05, 2012 10:15 pm
What diffs are you going to run with 37's? What WB are you looking at on 33's?
Post Posted: Wed Sep 05, 2012 10:32 pm
Going through the linking system atm and i tell you its alot harder then you think.
Id start with alot of research first then a 4 link calculator before you even touch the car.
Post Posted: Wed Sep 05, 2012 10:52 pm
I got a lot of info from there
Post Posted: Thu Sep 06, 2012 5:55 pm
ok than if its that much effot in the mean time untill i get around to it is there a way to flatten my leafs out so my car dosnt sit so high?
Post Posted: Thu Sep 06, 2012 8:16 pm
take out a few leafs
Post Posted: Thu Sep 06, 2012 8:34 pm
Is it sprung over with lifted springs ? If so replace them with some stock leaves to lower it or remove extended shackles if it has them. If you start removing leaves you will be more susceptible to axle wrap.
Post Posted: Fri Sep 07, 2012 4:24 am
Could get reverse rap mains made up that will lose a bit
Can u get the pack rest flat
How are the perches made
Can they be remade to sit lower
Vehicle: 1985 lwb sierra UTE
Post Posted: Sun Sep 09, 2012 3:13 am
U could do somthing simular .
http://www.rocky-road.com/samurai-coil-conversion.html.
Or for the spring over
make some perches like this
Post Posted: Sun Sep 09, 2012 7:32 am
Oops skim reading again
Users browsing this forum: No registered users and 315 guests
