It is currently Wed Oct 21, 2026 12:36 am
lesspostingmorewheeling
Post Posted: Wed May 20, 2009 2:16 am
i want to set up something so that i can adjust/hold revs without having to keep my foot on the accelerator for winching etc.
i have seen pushbike hand brake levers used as hand throttles but i'm looking for something that will "lock" the throttle at what ever revs i set it too similar to a manual choke.
has anyone done this or does anyone one have any ideas how i can do this?
Mike
Post Posted: Wed May 20, 2009 2:23 am
push bike gearshift levers :) the type that go on the downtube
Post Posted: Wed May 20, 2009 2:28 am
can you even still get those? i thought they stopped making them in like the 60s
i remember seeing a throttle lock on a f350 that worked similar to cruise control but with revs rather than speed did any other cars come out with something similar to this?
Post Posted: Wed May 20, 2009 2:31 am
Landcruisers. 75, 78 & 79 up to the 1HD-FT motor. The new V8's just have an idle up button
Post Posted: Wed May 20, 2009 2:32 am
how do they actually lock the throttle?
Post Posted: Wed May 20, 2009 2:35 am
They just wind. You can get ones that pull out and twist too, like the old Mini chokes
Post Posted: Wed May 20, 2009 2:37 am
plus early diesel hilux's and 40, 60 series landbarges.
Post Posted: Wed May 20, 2009 2:39 am
would it just be easier using a choke cable?
Post Posted: Wed May 20, 2009 3:03 am
Cant you just turn the park lights on for turning the revs up?
[URL=http://img406.imageshack.us/i/samuraifsmpdf.g
Post Posted: Wed May 20, 2009 3:11 am
Post Posted: Wed May 20, 2009 3:36 am
...hahahahaha..
How high do you want it to rev? 3k or something
Post Posted: Wed May 20, 2009 5:02 am
acc1 wrote:
...hahahahaha..
sierras like mine with carbies made in the 70s don't fancy things like idle up solenoids
i'd like to be able to set the throttle at what ever i want but the main reason would be for charging the battery while winching
Post Posted: Wed May 20, 2009 6:51 am
70's? That is old.. lol :)
Vehicle: 1999 Jimny
Post Posted: Wed May 20, 2009 10:27 am
Shut up junior!!!!! yess!!
Post Posted: Wed May 20, 2009 11:36 am
I'm sure MRW82 is using something like this for his endless air system. Try and track down a pull-and-twist choke cable, that'll be your best bet.
Post Posted: Wed May 20, 2009 12:41 pm
What about using the throttle lever and cable off an old Victa?
BLING CHROME...!
Post Posted: Wed May 20, 2009 12:59 pm
BLING CHROME...!
The carby also?
Another option would be something like off an MQ Patrol. They have a hand throttle knob on the dash, but the cable runs to a bracket off the top of the throttle pedal arm instead of going to the carby.
Post Posted: Wed May 20, 2009 3:27 pm
yep, thats all I use, a pull and twist choke cable. I have it mounted under the dash and it just connects to the accellerator cable/pedal.
I use it to lock the revs at about 2grand while using the endless air. It is also very handy for if you stall on a hill, you can keep your foot firmly on the brakes, have the accellerator locked on slightly and turn the key. always starts easier with a bit of go pedal and this makes it safe and easy.
Post Posted: Thu May 21, 2009 1:18 am
just graft a cruiser one in I'm going to do the same
 Profile YIM
Users browsing this forum: No registered users and 237 guests
