It is currently Tue Oct 20, 2026 2:09 pm
Post Posted: Tue May 26, 2009 12:23 am
Just wondering what some of you have used to adapt to top of carby? besider the standard 1.6 air filter box.
I dont have 2" body lift and i'm using the 1.3 airbox as my snork is on that side. The standard 1.3 metal hat dont fit to the 1.6 carby.
I'm going to look at pinch a part for something tomorrow to adapt to the top of the carby.
Ideally a nice 90 degree elbow straight on carby would be great, or a very small metal hat from another car if i'm lucky.
Any thoughts?
Post Posted: Tue May 26, 2009 12:45 am
I made a little adapter from a nylon cutting board :lol: it was a ring that sat on the carb (throttle body in my case) and the carb hat then sat on the ring.
First I used a 65mm holesaw to cut a circular piece from the cutting board. Then put a bolt thru the middle of it and tightened a nut down onto it. I could then mount the disc into my drill press which acted kinda like a lathe. For a cutter I just used a sharp wood chisel.
Post Posted: Tue May 26, 2009 3:19 am
so that was a nylon ring at the end?
Vehicle: 75 Cruiser
Post Posted: Tue May 26, 2009 11:20 am
I have a standard 1.3L metal hat that adapts to the 1.6L carby. It has been modified with a bigger ring welded inplace.
Post Posted: Tue May 26, 2009 12:26 pm
The end of what? It just sat on top of the carby.
Post Posted: Wed May 27, 2009 12:32 am
Sorry damo, at the end of your chiselling it was a ring that you were left with?
Post Posted: Wed May 27, 2009 12:41 am
isn't this shit running yet..... I guess you are using parts from Polar Bear & we all know how LONG that's taking!!!
:roll:
Post Posted: Wed May 27, 2009 12:58 am
Haha smart ass, mine almost ran today. started too run, then fuel was pissing everywhere out the fuel pump. cant wait too see what happens to the carby, since it hasnt been started forever(hey polarbear? :roll: ).
There's a hole in my bonnet dear liza a hole. Then mend it dear henry dear henry ...
Post Posted: Wed May 27, 2009 1:15 am
Yep exactly.
Users browsing this forum: Google Adsense [Bot] and 187 guests
