It is currently Fri Nov 06, 2026 5:34 pm
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2
Vehicle: Vit
Post Posted: Sun Oct 14, 2012 3:49 pm
Bummer bud, do u have a photo of how far off the snorkel sits? Cos I'm thinking of still buying one if it doesn't look too bad :P thanks mate
Post Posted: Sun Oct 14, 2012 4:32 pm
it's not ment to be flush against the A pillar, there should be a consistent 5-7mm'ish gap from the bottom of the A pillar up.
Vehicle: Vit
Post Posted: Sun Oct 14, 2012 5:30 pm
Yeah true mate :P
Vehicle: 2010 Suzuki Swift Sports
Post Posted: Sun Oct 14, 2012 8:52 pm
Yeah snorkel itself fits perfect, but the holes on the bracket on the A pillar needed to be shifted slightly. All done though. Will place up a how to and what I would have done different once I have the pipework connected to the air filter.
Post Posted: Mon Oct 15, 2012 1:53 am
Poita wrote:
Because the G16B snorkel pipe that goes into the engine is about 40mm to short, I need a rubber joiner/extender. But the snorkel pipe is that stupid tear drop shape.
I had the same problem when I fitted my Safari snorkel. I turned up an adapter from nylon that goes between the stock rubber and the airbox and sealed it all with RTV
Post Posted: Mon Oct 15, 2012 4:43 am
The factory hose actually fits, but I don't think it would be water proof...
Post Posted: Mon Oct 15, 2012 7:33 am
Do I need to block that 20c sized hole underneath the factory airbox inlet? It used to have a short pipe connected to the heat shield on the exhaust.
If so any clever ideas? I was thinking of using a milk cartoon lid, I think it would be about the right size!
Post Posted: Mon Oct 15, 2012 8:14 am
Called into autobarn this morning to pick up some silicone pipe. I need a 2.75" hose to connected to the snorkel and a 2.75" to 2.5" adapter hose to connect to the airbox. Will then get an exhaust shop to bend up a bit of 2.75" stainless pipe to go in the middle.
BUT autobarn want about $50 per silicone piece!!! Anyone know anywhere cheaper to get this stuff??
Post Posted: Fri Nov 02, 2012 8:31 am
Well snorkel is finally complete! Got the a stainless pipe welded up at my exhaust shop Very happy with the overall result despite the hassles.
Free plug for AM Performance, they do AWESOME work, did a full stainless exhaust for my Legnum.
Vehicle: Vit
Post Posted: Fri Nov 02, 2012 1:48 pm
looks good mate! shiny as! so you couldnt just cut a hole into the air box and wack some sealant around it? :)
Post Posted: Fri Nov 02, 2012 2:33 pm
Airbox? I'm not following you... the only thing I changed was the factory intake pipe. The actual MAF and air filter box is all factory.
Vehicle: Vit
Post Posted: Fri Nov 02, 2012 10:07 pm
That's cool man don't worry I wasn't making sense looks mad!
Users browsing this forum: Google [Bot] and 61 guests
