It is currently Wed Oct 21, 2026 10:25 am
Vehicle: 75 Cruiser
Post Posted: Mon Jun 01, 2009 1:24 pm
anyone got some suggestions for some half decent sierra shocks for a 2inch spring lifted sierra? for the rallycrapper zook. or would the normal commodore/hilux shocks still be ok fast stuff?
Post Posted: Mon Jun 01, 2009 2:04 pm
OME N76 shocks are designed for Baja 1000 VW buggies so would be a good shock but mounts will need work to make them fit.
Post Posted: Mon Jun 01, 2009 2:13 pm
the commodore shock in the front might be a bit "soft" in std for high speed work. maybe see if you can get some lowered shocks as most of the time they are a bit "harder" than std
Post Posted: Mon Jun 01, 2009 2:19 pm
I had Tellaflow and Boge shocks in my hardtop, they were the shocks that came with the original suzisport 2" kit
the tellaflows are adjustable and both seemed to work pretty well, used to be able to get them from the Suspension place in Petrie behind the mower shop but I dunno if they are even still there :)
I think the big factor would be fade, though the stages arent long are they?
oh and make sure they cant bottom out, otherwise they will be stuffed :)
Post Posted: Mon Jun 01, 2009 3:51 pm
Steve, most of the guys we know are running Pro Comp or Koni, Matt started with a tight budget so ran OME Hilux shocks in the front with the "stealth" mount modification and long travel OME's Suzuki shocks in the rear. This combination seemed really good till he went to Koni's which were noticeably better. As Royce said whatevr you use make sure they are not going to bottom out, you will be pushing housing hard into bump stops every event.
Post Posted: Mon Jun 01, 2009 11:08 pm
I think N76's will to too soft for a car built for speed.
Just my 2C. I love N76's, but they're not intended for a short travel/leaf high speed application. VW's are torsion bar.
Post Posted: Tue Jun 02, 2009 12:35 am
if the zook is leaf sprung, and will weigh about the same as a stock zook, i.e around 1000-1200 kg's the N76 will be fine. yes,it is built for longer than normal travel, but it will not be affected by short travel leaf suspension, its killer will be the wrong weight application.
Vehicle: Nissan
Post Posted: Tue Jun 02, 2009 1:31 am
hay steve talk to ryan at EFS brendale 32053088
that is where dad (Geepee) got ours from.
Pearce-toff Racing
Vehicle: 75 Cruiser
Post Posted: Tue Jun 02, 2009 10:31 am
ooo Thanks for all the suggestions! I'll have to get some prices.
Post Posted: Tue Jun 09, 2009 11:21 am
kinda on subject. but with a spoa setup what are people running
Users browsing this forum: Google [Bot] and 110 guests
