It is currently Fri Nov 06, 2026 6:50 pm
Vehicle: 96 sierra, 2 inch lift
Post Posted: Mon Oct 22, 2012 2:06 pm
Hey guys
Went to re kit my swivel hub and wheel bearings on the weekend, pulled the hub, wheel bearings apart, knocked the bearing cups out out, then went install everything and the kit I brought all the seals and bearings were wrong went back to the shop and discovered I actually have a vitara front end, is there any particular reason why the last owner changed the front end ?
Post Posted: Mon Oct 22, 2012 2:13 pm
you have a coily.
the wheel bearings in them were the same as a vitara from the factory.
Post Posted: Mon Oct 22, 2012 2:15 pm
Ahh right I see cheers for that information.
Post Posted: Mon Oct 22, 2012 7:29 pm
And brake rotors are also the same as Vitara, too, if you ever go to replace them. Not the same as every other Sierra disc!
Users browsing this forum: No registered users and 46 guests
