It is currently Fri Nov 06, 2026 6:08 pm
Vehicle: 1.6 carby Sierra
Post Posted: Wed Oct 24, 2012 9:24 pm
i was wondering if it is possible to put a Efi vitara head on a carby 1.6 vitara block
Post Posted: Wed Oct 24, 2012 9:59 pm
change pistons
wiring
exhaust manifold
Post Posted: Wed Oct 24, 2012 10:09 pm
so it does bolt on but you need everything from the con rods up
do you know if a 1.6 baleno head will work?
Post Posted: Wed Oct 24, 2012 10:29 pm
Pistons need to be changed for head valves
Pretty much middle up.
What year baleno? Dizzy models need vit cam anyway for a 90degree dizzy. Coilpack models need a crank sensor, not easily modded into a normal block. Better off getting a whole Bal motor
Post Posted: Wed Oct 24, 2012 10:53 pm
probably better of geting the full Efi from the vitara then, looks like less trouble
Post Posted: Wed Oct 24, 2012 11:22 pm
Do you know if your sierra has a sierra sump? It drops a lot at rear of motor
Some people have enough room for vit sump
All will be bolt in as you already have a adapt plate or something to suit the gbox
Post Posted: Thu Oct 25, 2012 10:15 pm
ive already got the fully vitara carby motor in, but the carby is on the way out so i was lookinf for another option with more power
Users browsing this forum: No registered users and 81 guests
