[ 7 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
Rossco
Joined: Fri May 28, 2010 10:28 am Posts: 529 Location: Townsville, QLD
Vehicle: 91 WT 1.6EFI
 Posted: Thu Oct 25, 2012 11:30 am |
Over night my vit G16B has developed a tapping sound. I think its coming from the head and it sounds like someone is hitting the engine with a hammer really quickly. I have been having a few issues with the car lately, I have replaced the ignition coil and the alternator and mucked around with the timing a bit because I pulled the dizzy out and didn't mark anything. not sure if any of these things have caused or contributed to this noise. there is also what sounds like a belt squeek. I thought it was the fan belt or the alternator but I have both tightened and loosened them and it hasn't changed the noise. perhaps the tap and squeak are related? Any ideas?
Rossco
 Posted: Thu Oct 25, 2012 1:03 pm |
Ok I seemed to have fixed everything somehow. it must have been pinging, I had never heard it before and didn't think it would be so loud/violent.
atari4x4
 Posted: Thu Oct 25, 2012 1:06 pm |
put 98ron fuel in it if it's pinging or reset your timing.
Rossco
 Posted: Thu Oct 25, 2012 1:29 pm |
ya I just fiddled around with the timing a bit more. I'm pretty sure it's at about 6 degrees now. I'm trying to get the the over-run burbles back since I stuffed up the timing last Friday.
JrZook
 Posted: Thu Oct 25, 2012 1:53 pm |
Rossco wrote: ya I just fiddled around with the timing a bit more. I'm pretty sure it's at about 6 degrees now. I'm trying to get the the over-run burbles back since I stuffed up the timing last Friday. How did you measure it?
Rossco
 Posted: Thu Oct 25, 2012 1:57 pm |
I lined the marks on the fly wheel up to 6 and adjusted the rotor to the centre of the pick up coil
zukmeista
Joined: Sun Mar 22, 2009 10:30 pm Posts: 1273 Location: Whangarei,N.Z.
 Posted: Thu Oct 25, 2012 2:09 pm |
You need to do it with a timing light to set it properly.
[ 7 posts ] |
Users browsing this forum: Google [Bot] and 95 guests
