It is currently Tue Aug 04, 2026 5:54 am
Post Posted: Tue Oct 02, 2012 6:04 pm
I went wheeling at Levuka last weekend. I had made some 2" extended shackles and borrowed the young fella's 29's, and what a difference it made to clearance, but what a pig to drive, virtually nil lateral stability. Dropped driver's front wheel into a hollow down a hill and nearly fell over - luckily it was in a gully and I could put my arm out and save it. Not much fun to drive on the road either, so how much difference could I expect if I fitted WT diffs? I really like my f10A, but I don't think it would like higher diff ratios, so is there such an animal as WT diffs with 1.0L ratios, and if so are they a rare and sought after commodity? I can visualise the conversion, and recall seeing the brackets for sale somewhere, but is it worth the effort
Post Posted: Tue Oct 02, 2012 6:09 pm
:hey:
Yes WT is worth it.
Yes you can get 1L ratios for WT diffs. They can be found in ANY WT Maruti. Must be a WT model though.
Yes, someone here sells new perches, and can even use his JIG to glue them on for you :wink:
Post Posted: Tue Oct 02, 2012 6:13 pm
:hey:
Yes WT is worth it.
I did think it was you that sold them Mr Fat, so I think I might start the hunt. Can the centres in the 1.0 WT diffs be changed should I change to 1.6 down the track?
Post Posted: Tue Oct 02, 2012 6:16 pm
yep. WT 1.3, NT 1.3, and WT maruti are all interchangable. They also accept vitara front R&P's, so that opens up more gearing options should you be chasing reduction at a later date.
I must stress that it is ONLY the wt maruti (4.11:1) that will fit a 1.3L housing. The NT maruti is identicle to your current diff in every way.
Post Posted: Tue Oct 02, 2012 6:25 pm
PM rhino, he had a pair for sale a while ago, may still have them.
Vehicle: Yellow Ute
Post Posted: Tue Oct 02, 2012 8:04 pm
This is worth it too, atleast get something that is the same or lower geared than 1ltr, when I put the WT diffs in mine I used NT 3.9 centres and that was even annoyingly noticeable.
Vehicle: 4wd
Post Posted: Tue Oct 02, 2012 8:18 pm
Brave putting your arm out to save the car.
Watch out or you'll get sued.
Post Posted: Tue Oct 02, 2012 8:19 pm
I'd risk a broken bone to save the taxi :wink:
Post Posted: Tue Oct 02, 2012 9:16 pm
In hindsight probably right, but possible injury vs definite panel damage I guess it was just a natural reaction. Did get the help across the gully fairly quickly though :D
Mr Fat, can I get lockers to fit the Maruti diffs?
Post Posted: Tue Oct 02, 2012 10:31 pm
Yep. For all intensive purposes, a WT maruti diff is the same as a WT sierra diff. Bearings, seals, lockers, axles etc etc.
Vehicle: 1985 lwb sierra UTE
Post Posted: Wed Oct 03, 2012 9:07 pm
could u make a hybrid centre out of the wt ones and 1l ones beering in mind iv never seen a 1l 3rd member
Post Posted: Wed Oct 03, 2012 9:24 pm
No. The hemisphere, Crown wheel and Pinion are all much smaller in the 1L third.
1l is the same size as LJ50-80.
Post Posted: Thu Oct 04, 2012 5:30 am
WT maruti centres
http://auszookers.com/forum/viewtopic.php?f=7&t=36129
Vehicle: '94 suzuki maruti
Post Posted: Thu Oct 04, 2012 6:14 am
the maruti diff centre combined with a 1L transfer case makes the car just about perfect on the road with 31's. my tired old 1.3L engine can still haul my maruti along at 100, more if it feels like it.
Vehicle: 89'SWBsierra&84'LWBsierra
Post Posted: Sat Oct 27, 2012 4:40 pm
not sure if this is the right tread to but this in but its better then starting a new one. I have just started doing this conversion to my 1.3L LWB NT sierra. my question is would the diff ratios between the 1.3L NT and the 1.3L WT be the same? the reason i ask is cause the WT centre won't bolt up to drive shaft. what is the easiest fix, swap the diff centres or can you undo the nut on the diff flange and swap them over?
what are the ratios of:
1L NT diffs
1.3L NT diffs
1.3L WT diffs
Thanks greg
Vehicle: Daisy
Post Posted: Sat Oct 27, 2012 5:44 pm
You can change the flanges pretty easily, worst case if you don't have flanges to swap you can slot the hole on one (bolt still can't spin out because you've only slotted one flange).
Afaik
1.3L NT = 3.9 ratio
1.3L WT = 3.7 ratio
Post Posted: Sat Oct 27, 2012 6:50 pm
Swap diff centres
The NT front centre is 4 pin (which is better), the WT is 2 pin
The NT ratios are also a little more useful (there is an annoying difference between 3.9 and 3.7, it isn't much, but you do notice it). Revving 5% higher is tolerable, revving 5% less than ideal is irritating, because you will be between 4th and 5th a hell of a lot!
Users browsing this forum: UBZ and 271 guests
