It is currently Fri Nov 06, 2026 11:42 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2
Post Posted: Tue Oct 30, 2012 7:33 am
Here are some pics of how I rerouted my exhaust, on a budget. I had to move it properly to get around the lwb vit tank, and to stop it rattling.
I also moved the exit up much higher, as it was often gouging into the ground.
I pulled the old exhaust out and carefully removed every bend to reuse.
I got some flange gaskets, then made some flanges out of 5mm plate, drill and hole-saw. The outside shape was with cutting disc on an angle grinder, and a bit reckless. I didn't care, as long as it was worked.
I also didn't clean it very well before welding, and welds look terrible.
I cut the exhaust pipe going into the muffler to redo the angle to position the muffler to be where I wanted it.
I needed to finish, and needed more straight pipe, and an extra bend. Which is why I had to use 39nb pipe.
It needs to be extended at the output slightly, but I'm pretty happy with it.
When I do my efi, and aw4, I will redo the exhaust, with 2" extractors to the exhaust, and 1.75" after the exhaust.
Post Posted: Tue Oct 30, 2012 7:50 am
Has anyone managed to stick the zorst out the drivers side? I want to put some stuff where the muffler goes and it would make it easy if I could route the zorst to the drivers side.
Post Posted: Tue Oct 30, 2012 8:31 am
The fuel lines, fuel filter, and fuel filler hose, turned me off the idea of the exhaust on drivers side.
I agree with the idea, the mufler is in a huge waste of space and does little to help balance the weight in a rhd vehicle, but i really dont like burny things.
Post Posted: Tue Oct 30, 2012 11:48 am
I have a fuel filler on the passenger side as well so no matter which side the zorst is on it will go near a fuel filler
Post Posted: Wed Oct 31, 2012 10:09 pm
... and you like burny things.
Users browsing this forum: Google [Bot] and 55 guests
