It is currently Fri Nov 06, 2026 5:12 pm
Post Posted: Tue Oct 30, 2012 6:55 pm
Hi guys im going for a wheel this weekend and i am running a 4 inch lift in my jimny and have yet to install the prop spacer. (ORA LIFT)
I was wondering if anyone has run such a lift with no prop spacer and if its allright. (im not going to do any jumps or anything)
Vehicle: 4wd
Post Posted: Tue Oct 30, 2012 7:13 pm
Why don't you fit it?
Watch out or you'll get sued.
Post Posted: Wed Oct 31, 2012 10:15 am
Im thinking about going with the same kit. are you happy with the kit?
Post Posted: Wed Oct 31, 2012 10:25 am
hmmmm.... if it wasn't necessary do you think they would have supplied it with the kit, they could be saving money by not supplying a spacer if it wasn't needed. :?
Vehicle: Vit
Post Posted: Wed Oct 31, 2012 11:10 am
With an 75mm lift in the back of my vit I didn't need a prop spacer :P
Post Posted: Wed Oct 31, 2012 12:07 pm
Do you have corrected radius arms? How much spline is inside the front yoke.
If you feel that it needs more add a spacer.
Post Posted: Wed Oct 31, 2012 12:11 pm
ORA arms move the axle forward so the spacer is to allow for that plus gives extra clearance at the crossmember if you install it at the transfer end of the front shaft.
Users browsing this forum: No registered users and 82 guests
