It is currently Tue Oct 20, 2026 12:35 pm
Vehicle: MY2019 Jimny
Post Posted: Sat Jun 06, 2009 11:27 am
Does having an airlocker affect which weight oil you run in your diff?
I am fitting one today and need to go shopping first...
ALso, are axle seals usually off the shelf?
Last edited by lump_a_charcoal on Sat Jun 06, 2009 12:46 pm, edited 2 times in total.
Post Posted: Sat Jun 06, 2009 12:10 pm
lump_a_charcoal wrote:
Does having an airlocker affect what weight oil you run in your diff?
I just run normal 'ole 80W90 in mine. Check the ARB site maybe? Joe might chime in at some stage too, he'll probably know for sure.
Post Posted: Sat Jun 06, 2009 12:14 pm
book says LSD oil, LS90 seems ok
Post Posted: Sat Jun 06, 2009 12:15 pm
The ARB book?
If so, thanks.
If not, WTF?!
Post Posted: Sat Jun 06, 2009 12:57 pm
Also, is $23 per axle seal expensive?
Post Posted: Sat Jun 06, 2009 1:16 pm
yeah arb book
I am pretty sure I used to pay 28 for a wheel bearing and seal :)
try a bearing shop, not a car parts shop
Post Posted: Sat Jun 06, 2009 1:21 pm
Have since found them for $4.50 each...
Thanks fellas.
Post Posted: Sat Jun 06, 2009 1:26 pm
Royce, is the 1/8th BSP tap the one for breather mods? Also, is it tapered?
Post Posted: Sat Jun 06, 2009 1:29 pm
on the rear? I just use 1/2" hose
or for the swivels? if so yes :)
Post Posted: Sat Jun 06, 2009 2:48 pm
That's what I used on mine, 1/8" BSPT.
Post Posted: Sun Jun 07, 2009 12:05 am
i rang ARB coopers plains today & they use castrol lsx90/140 to suit aussie conditions in the diffs. :!:
Post Posted: Sun Jun 07, 2009 12:23 am
Nephew works at ARB Penriff, and reckons they use Penrite LSD oil in diffs they just fitted air lockers to. From memory I think it's 80w/90
Post Posted: Sun Jun 07, 2009 1:05 am
I asked arb melb when I did mine they said to use what ever oil was rated for the diff originally.
so I guess 80/90w is the go if its a zook
Post Posted: Sun Jun 07, 2009 4:36 am
BAH!!!
Guess who installed the diff centre without checking which flange it has?
Correct, me.
Now I have to replace it with a WT one tomorrow - Hopefully I can get the locknut back in the right spot...
Post Posted: Sun Jun 07, 2009 2:42 pm
thats a pain,as long as you get it back to the right spot it'll be sweet eh.
dont be like me and have a wt n a nt rear half of the shaft for either my welded or open centre :wink:
Post Posted: Sun Jun 07, 2009 3:32 pm
I have no option, either I change the flange or I miss work on tuesday, so flange it is.
If the backlash or preload (can't remember which) isn't spot on, will it cause issues that could damage the airlocker, or just the R&P?
Users browsing this forum: Google [Bot] and 158 guests
