i've heard of ricers making up a de-cat pipe & that's just a piece of exhaust pipe the same diameter as the exhaust welded into the cat after punching the guts out of it so at least it looks like your running a cat if you ever get pulled up
This would be what I would do, if I had to.
But replacing the cat would be the priority, once the reason for the cooked cat is fixed.
Users browsing this forum: Google [Bot] and 84 guests
