It is currently Fri Nov 06, 2026 4:31 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page 1, 2  Next
Post Posted: Thu Nov 01, 2012 1:38 pm
Off-Road and Goods Vehicle Wheel Track
The wheel track of off-road four wheel drive vehicles and goods vehicles (MC, NA, NB ADR
category) must not be increased by more than 50mm beyond the maximum specified by the
vehicle manufacturer for the particular model.
If a solid axle from another manufacturer is used, the wheel track may be increased by 50mm
beyond the maximum specified by the vehicle manufacturer for that particular axle, provided all
other requirements such as clearances and the tyres do not protruding outside of the vehicle
Post Posted: Thu Nov 01, 2012 1:41 pm
looks like NCOP has made my build easier rather than harder!!
Post Posted: Thu Nov 01, 2012 1:42 pm
Nice! I like it.
Post Posted: Thu Nov 01, 2012 2:12 pm
so how much wider are hilux axles then WT axles
Post Posted: Thu Nov 01, 2012 2:28 pm
From memory 60-65mm a side?
Post Posted: Thu Nov 01, 2012 2:30 pm
from the axle widths thread on here.
Hilux (79-85)
Front 1397mm
Rear 1397mm
Sierra WT
Front 1340mm
Rear 1350mm
that wms to wms
not including wheels
Post Posted: Thu Nov 01, 2012 2:31 pm
tanshi wrote:
and
Hilux (86- )
Front 1397mm
Rear 1473mm
Post Posted: Thu Nov 01, 2012 2:41 pm
1410 with wheels from what i can find
and sierra had +5 wheels so i would think that makes it around 1387mm centre of wheel to centre of wheel
Post Posted: Thu Nov 01, 2012 2:59 pm
Aren't coily diffs wider then WT?
Vehicle: SJ80, SE416
Post Posted: Thu Nov 01, 2012 3:06 pm
Yup! :thefinger:
...the reason they had greater positive offset rims out of the factory...
Post Posted: Thu Nov 01, 2012 3:08 pm
yeah, its about 15mm a side or similar
Post Posted: Thu Nov 01, 2012 3:16 pm
Well that is anouther 30mm ya can go wider
Post Posted: Thu Nov 01, 2012 3:19 pm
would that be 30mm wider just for coilys though?
Post Posted: Thu Nov 01, 2012 3:21 pm
yeah different model number.
but you can mod plate coily diffs under a leafy if you wanted too.
or just put MOGs under there
Post Posted: Thu Nov 01, 2012 3:31 pm
does it say anything in regards to SPOA or are you intending on going SPUA on the lux diffs?
Sierra, 32's, Airlocked, 6.5'd, hopefully ruf soon
Post Posted: Thu Nov 01, 2012 3:34 pm
i havent seen anything re SPOA,
i guess it would be possible now. max lift is 150mm but you need to do lane change tests etc
Vehicle: Daisy
Post Posted: Thu Nov 01, 2012 4:22 pm
So how does that go for putting WT diffs under an NT? Shouldn't be any drama at all? Or completely not allowed because it's the same manufacturer...
Post Posted: Thu Nov 01, 2012 4:23 pm
mod plateable as a diff swap
Vehicle: Daisy
Post Posted: Thu Nov 01, 2012 4:25 pm
Woo, I thought they already were because anto86 was talking about doing it but it's good to hear confirmation!
Post Posted: Thu Nov 01, 2012 4:30 pm
they technically were allowed but within the old rules you were supposed to only be 50mm wider than the original diff.
WT is 90mm wider than NT so you should run inset wheels to get back to 50mm
now you dont have to
Vehicle: 1985 lwb sierra UTE
Post Posted: Thu Nov 01, 2012 6:18 pm
Is all the new ncop stuff passed yet, I thought it was still in the works. Or have got left behind and it is in action known?
Post Posted: Thu Nov 01, 2012 6:26 pm
Effective as of today.
Post Posted: Thu Nov 01, 2012 6:55 pm
Got a link to check it out?
Post Posted: Thu Nov 01, 2012 8:57 pm
http://www.google.com.au/search?client= ... iQfV-YHYAw :thefinger:
Post Posted: Thu Nov 01, 2012 9:03 pm
There dated for Jan last year
Post Posted: Thu Nov 01, 2012 10:21 pm
Keeping it legal... thread JCB wrote
"Leaf spring suspension must not be raised through the use of extended shackles, adjustable metal plates or by placing the leaf springs to the opposite side of the axle"
Is this a reference to SPOA?
Post Posted: Thu Nov 01, 2012 10:38 pm
I think so but it's all very confusing
Post Posted: Thu Nov 01, 2012 10:41 pm
Alright, fine...
http://www.tmr.qld.gov.au/~/media/Safet ... ns1112.pdf
or
http://www.tmr.qld.gov.au/Safety/Vehicl ... tions.aspx
QCOP can be downloaded in sections about 2/3 of the way down the page.
VSB14 which became NCOP: http://www.infrastructure.gov.au/roads/ ... _ncop.aspx
Approved inspection station code of practice: http://www.tmr.qld.gov.au/Safety/Vehicl ... ctice.aspx
Happy reading! I'm off to find the NSW version...
Post Posted: Thu Nov 01, 2012 11:05 pm
Very good Darkhorse :)
Users browsing this forum: No registered users and 70 guests
