It is currently Wed Oct 21, 2026 9:41 am
Post Posted: Wed May 27, 2009 10:08 pm
Just wondering where you guys have mounted your recovery hooks on your leaf sprung Sierra's. Photos would be good.
Post Posted: Thu May 28, 2009 12:31 am
i originally had the first pic, than i made a rear bar and now i have second pic
they both work well
Post Posted: Thu May 28, 2009 2:35 am
Thanx 11_Evl.My car has a standard body, right down to the original bumpers for now, so neither of those points are any good to me. I like the photo's though and judging by the love taps on your car, remind me to wear my brown undies if I ever come and ride shotgun with you ;)
Post Posted: Mon Jun 08, 2009 3:58 am
hay mate iv put some on the rear of my coily im prity sure u can do it the same on a leafy.
i just used 1 of the holes at the rear were u mount a tow bar (the 1 in line with the chasie) and drilled a hole behined it, than i bolted a 3500kg recovery hook to it and i also put some 5mm steal plate each side, its heeps strong iv pulled big patrols and luxes out with it and havent had a problem i just use a exulizer strap to spread the load when its a big recovery.
hears some pics
cheers scott
black coily, 30 inch tyers, 2 inch suspention, 2 i
Post Posted: Mon Jun 08, 2009 5:39 am
do you have a towbar ?
i just made a shorter piece of 10mm plate with the tow ball tongue bolt pattern with a hole big enough for a large d shackle pin.
sam
Post Posted: Mon Jun 08, 2009 11:51 am
Don't have a towbar yet, but it is on the cards. That's probably the best idea for a recovery point on the rear, and will probably be the way to go.
@ Scottysj80 That is where I originally intended fitting them on the rear of my car, but after I inspected it, I realised the leaf spring shackles would hit under flex if I fitted them there.
What about the front of the car??
Post Posted: Mon Jun 08, 2009 3:12 pm
Just don't get stuck
Post Posted: Mon Jun 08, 2009 3:28 pm
well done, best recovery hook idea ever, i might just go and do that to my sierra right now and never have to worry about an unsafe recovery every again. lol
Post Posted: Mon Jun 08, 2009 7:03 pm
I don't get stuck. I wanted recovery points so I could get all the bigger cars in our club out of the shit :lol:
Users browsing this forum: Google [Bot] and 74 guests
