[ 5 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
Bucket
Joined: Mon Nov 30, 2009 10:30 pm Posts: 2191 Location: Vic
Vehicle: SJ50 hardtop!
 Posted: Sun Nov 11, 2012 3:31 pm |
Turns out what I thought (twice now) was the common leaky seal between the dizzy housing and the engine head, is wrong. I've sealed the fucker twice over and it still seems to be leaking, but I found that there is oil further up the distributor itself.
Opposite the adjuster on the dizzy, underneath is what seems to be a hole. Is it a breather?? I kinda think that's where it's leaking from. Is there anywhere else I should be checking?
Scrawny
Joined: Tue Jan 29, 2008 10:30 pm Posts: 10528 Location: Brissie
 Posted: Sun Nov 11, 2012 3:53 pm |
stockman
Joined: Thu Nov 05, 2009 10:30 pm Posts: 5319 Location: Canberra
Vehicle: 4wd
 Posted: Sun Nov 11, 2012 5:20 pm |
There is two seals. Both rubber o rings. If you have only done one then do the other.
_________________ Watch out or you'll get sued.
stockman
Vehicle: 4wd
 Posted: Sun Nov 11, 2012 5:21 pm |
Also, you don't need to add sealant. It's an o ring not a gasket.
Bucket
 Posted: Mon Nov 12, 2012 10:45 am |
I did both oring and sealant just to be safe.
Ended up replacing the other o-ring on the shaft because it was rock hard, but have discovered that the leak is coming from the back of the tappet cover housing.
Spoke with Greg at 4wd_products on eBay and I already have a new gasket on the way. Would recommend him!
[ 5 posts ] |
Users browsing this forum: UBZ and 273 guests
