It is currently Tue Aug 04, 2026 4:21 am
Post Posted: Tue Nov 27, 2012 8:26 pm
I have done a cooling system pressure test, it kept 10 psi for 10+ min so no issue there
Done a co2 test, no issue there. Not even a slight colour change in the test fluid
Replaced the radiator with a known good one with a new cap.
I am sure it has no thermostat as even at idle the coolant fair races around.
The water pump has been replaced, however it looks like he lost a few bolts. Can see 3 missing from the pump
It doesn't run hot and Infact seems to be a great little motor.
http://i415.photobucket.com/albums/pp23 ... 10B1AE.mp4
The harder I rev it the more coolant blows out the overflow
Any suggestions?
Post Posted: Tue Nov 27, 2012 8:30 pm
Put a thermostat back in
Post Posted: Tue Nov 27, 2012 8:43 pm
A thermostat doesn't explain why the radiator is being pressurized. Something else is going on besides flow. It dumps into the overflow bottle but then doesn't suck the coolant back into the radiator.
Post Posted: Tue Nov 27, 2012 8:46 pm
cavitation
Post Posted: Tue Nov 27, 2012 8:47 pm
head gasket? pressurising the water jacket?
Post Posted: Tue Nov 27, 2012 8:50 pm
test fluid would change colour if that was the case
Post Posted: Tue Nov 27, 2012 8:51 pm
Passed a co2 test so no combustion gasses in the coolant
Post Posted: Tue Nov 27, 2012 8:53 pm
ball wrote:
cavitation
Can cavitation create pressure in the radiator ?
Post Posted: Tue Nov 27, 2012 8:57 pm
mate that is exactly what happened to mine, when you did the co2 test was the engine hot? the engine needs to be at operation temp, sometimes those testers can not change colour but its still stuffed, the fluid also shouldnt be reused. Try a different bottle.
mine turned out to be a crack in the block but could also of been a head issue (bought a new head). I ran mine with this issue for 6 months, just swapping the over flow coolant back to the rad.
good luck
p.s cavitation is air bubbles, so yeah i would think that it would create some pressure. You said the water pump was new, so unlikely
Vehicle: SJ51T
Post Posted: Tue Nov 27, 2012 9:09 pm
I had this problem from the get go with my GTI. I never tested anything. It would pressurise the cooling system to a point where if i took the cap off it would squirt out everywhere even though the coolant was cold. Over flow bottle would always be overflowing when the motor was hot. And last month the head gasket blew enough the make it misfire. Nice puddle of coolant was waiting for me in cyl 3 when I pulled the head off.
Oh yeah when do you need that Tcase flange?
EDIT: Just watched the video, I don't recall mine doing that if I stabbed the throttle.
Post Posted: Tue Nov 27, 2012 9:13 pm
No rush for the tcase flange mate. Thanks
Vehicle: SJ51T
Post Posted: Tue Nov 27, 2012 9:15 pm
Oh good.. Its about an hour from my place, I didnt want to drive there just for it. I will be going there next week tho.
Post Posted: Tue Nov 27, 2012 9:27 pm
It only looks new and is taking the word of the dude he got it from. I would be checking the pump.
Post Posted: Tue Nov 27, 2012 9:38 pm
I don't really want to check anything he did as I feel it will be a shitload of work fixing all the stripped threads and replacing the missing bolts.
I just want the thing to work properly so I can do fully sick skids
Post Posted: Tue Nov 27, 2012 9:42 pm
you should be able to get recoil kits cheap :wink:
Vehicle: SJ51T
Post Posted: Tue Nov 27, 2012 9:45 pm
Take the fan belt off and see what happens?
Post Posted: Tue Nov 27, 2012 9:48 pm
sssshhhhhhhhhh
I want to see him sweat and pull the pump. :lol:
Post Posted: Tue Nov 27, 2012 10:05 pm
That's thinking :D will do that tomorrow
Post Posted: Tue Nov 27, 2012 10:37 pm
nice water feature, PM Cuzz-Tech... he's the GTI guy!
Post Posted: Wed Nov 28, 2012 5:18 am
Do this, just for shits and giggles
Post Posted: Wed Nov 28, 2012 6:19 am
Any suggestions?
Put the cap back on, cant get out if there is no hole :peaceout:
I would put a thermostat back in so the top of the core isnt the restriction, ive seen similar with an electric pump doing the same thing
those sniffer tests arent the be all and end all either, ive got 2 pics here somewhere, one of the vit passing a sniffer test and one of the head off it thats cracked from end to end pompoms
Post Posted: Wed Nov 28, 2012 6:22 am
Fast water flow in the top tank suggests a (partially) blocked radiator.
Water needs to flow faster to get an equivalent volume through less tubes.
Gushing out the spout like that screams head gasket to me.
Combustion pressure is getting into waterways and pushing water out with it as it escapes, the water isn't being recovered from the overflow bottle because there is no vacuum in the cooling system due to the bubbles being added when engine is hot/running.
Post Posted: Wed Nov 28, 2012 5:49 pm
Decided that I will ignore it and see if it goes away. If it doesn't go away I will pull it apart in a couple of weeks.
Anyone know where I can get a fsm for a mk1 GTI swift?
Post Posted: Wed Nov 28, 2012 5:58 pm
Yank site I know :thefinger:
http://www.suzuki-forums.com/suzuki-swi ... tro-forum/
Vehicle: SJ51T
Post Posted: Wed Nov 28, 2012 8:00 pm
https://docs.google.com/file/d/0B259Lia ... N0UXM/edit
That link has a zipped workshop manual for a GTI + general motor stuff.
Vehicle: 92 tintop sierra
Post Posted: Wed Nov 28, 2012 8:11 pm
I should read more
Post Posted: Wed Nov 28, 2012 8:17 pm
I'd be saying that's a head gasket for sure! I wouldn't rely on one of them co2 testers anyway.
Users browsing this forum: fordem, Google [Bot] and 238 guests
