It is currently Mon Aug 03, 2026 10:41 pm
Post new topic Reply to topic  [ 40 posts ]  Go to page 1, 2  Next
Vehicle: Suzuki Jimny
Post Posted: Fri Nov 30, 2012 3:43 pm
When I put my g16b engine in my lj80 I want to turbo it just wondering what the best turbo is for it and what manifold? Thanks guys
Post Posted: Fri Nov 30, 2012 3:46 pm
GTFO if you have to ask those sorts of questions, you aint ready for turbo kiddo.
Post Posted: Fri Nov 30, 2012 3:56 pm
I need Steve he seems to b the only one who give me good info
Post Posted: Fri Nov 30, 2012 4:00 pm
lol steve is gonna tell you the same thing.
you planly dont know anything about boosting a car and its alot more complicated than strapping a turbo on the side.
Post Posted: Fri Nov 30, 2012 4:01 pm
how about having a search, there is some good info in 00ZOOK & canberramav's build thread + heaps of other random turbo threads that dreamers keep starting but end up going no-where like this one will.
Post Posted: Fri Nov 30, 2012 4:08 pm
Right thanks
Post Posted: Fri Nov 30, 2012 4:11 pm
what happened to the J20a conversion from last thursday...
viewtopic.php?f=5&t=34595
:roll:
Post Posted: Fri Nov 30, 2012 4:15 pm
I brought a g16b on Wednesday. Got 1 with 180,000ks for $400 with computer,loom,dash,fuel tank. That's cheap hay
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Fri Nov 30, 2012 4:17 pm
I hope you got the loom and computer too...
Post Posted: Fri Nov 30, 2012 5:33 pm
Sorry Cayden, atari is mostly on the money.
I'll reiterate this in the event that your searching doesn't find one of my posts about it from the past.
I think there's two types of people who look into boosting a motor for a 4WD application - those who are really keen to stat a long, complex and very expensive process for shits and giggles, and those who want a car that makes full hektik noises.
Firstly, you might want to get your project running with the atmo G16B in it and see how it drives. Most people think that a light car like a SWB sierra or LJ goes quite well with just a G16B in it. My sierra is pretty heavy, runs an auto, and 35's and I still think it drives quite well with a nothing-special atmo G16B.
For you to want to roughly double the output of a G16B, you'd need a truckload of traction to make it do anything except light the tyres up and generally be dangerous to drive.... and if you have that much traction, you're likely to discover that none of the suzuki driveline is strong enough.
I'll reiterate - you can only use as much power as you have traction.
Turboing a G16B is going to cost around $6K. At the end of that process, you're going to have around 150 KW and 250Nm of torque, but you're going to have achieved it the most expensive possible way, and with the most fragile possible outcome. Everything is going to be custom. You can get those numbers really easily out of a number of factory turbo 1.8-2.0 litre motors, and they'll last forever. Turbo G16B's don't tend to last all that well at all.
In any case - say you do drop the coin and get it all sorted - what was the point? to say you have done it, or to add capability - because all that horsepower is only going to add capability for a tiny fraction of the time you're driving the car, the rest of the time, all that complexity and all those aftermarket parts are just a liability.
Have I turboed a G16B? No. I don't need to learn from my own mistakes in this case - I can learn from others. I love funny spooly noises and wastegate choof as much as the next man. I've owned a number of factory boosted cars, but funny noises aren't enough to justify the cost or drama.
Vehicle: 1985 lwb sierra UTE
Post Posted: Fri Nov 30, 2012 5:43 pm
Well put Steve, and I mean that very nicely cayden a turbo 1.6 is nuts still cool, but to do it properly is going to cost big $$$
There is more then just bolting a turbo on u need to completely rebuild the engine not reco, but upgrade parts and Ur compression ratio needs to be correct.
Also the Geer box may need upgrading I'm not sure.
I also want as much power as Ican get but there has to be a limit and a balance . Performance to reliability
Post Posted: Fri Nov 30, 2012 5:51 pm
and then there is the cost of getting it tuned properly.
i'll buy keensy a carton of beer if the OP ends up with a reliable turbo G16b in less than 12 months time. :beer:
Post Posted: Fri Nov 30, 2012 7:34 pm
Damn it no beer for me
Post Posted: Fri Nov 30, 2012 7:54 pm
Thanks guys. I think il just stick with the standard g16b
Post Posted: Fri Nov 30, 2012 8:12 pm
I drove a g16b vit today and the power difference to my sierra is pretty impressive! No wonder its such anpopar conversion. I would love to have that motor in my sierra!
Vehicle: 1995 soft top vitara
Post Posted: Mon Dec 10, 2012 4:51 pm
my g16b is running a s15 ball bearing t28 turbo on a custom fabricated steam pipe manifold. costs alot of money to turbo charge one succesfully. i run around 14 psi, threw a built motor and it has made over 200rwhp on a few occasions. the setup has done almost bang on 10,000ks without any real problems
if i went back in time i wouldnt bother doing it again, i would build a tough na setup.
Vehicle: '96 LWB trayback
Post Posted: Mon Dec 10, 2012 5:15 pm
Once again, dyno graph or stfu ;)
Post Posted: Mon Dec 10, 2012 8:39 pm
was having problems trying to resize the pic. dont take notice of the date, it is wrong. that tune was done around 6 months back. now that ive got a photobucket acc ill post some up of the whole car hahaha
http://s1320.beta.photobucket.com/user/ ... 2770368285
Post Posted: Mon Dec 10, 2012 8:47 pm
Armsup build thread or ban :deadhorse:
was this the turbo one that was advertised on here a while back with the full cage & a fair bit of fruit and there was a 2nd one that was built to similar specs?
Post Posted: Mon Dec 10, 2012 8:55 pm
i brought a banged up comp car, with 15k worth of reciepts for the engine locally. then had the engine freshened up, and put it into a fresh gun metal vit soft top. just finished it really, had the steel diff put in it with some sort of locker. new cvs, avm hubs etc, pretty much a new car these days. goes great, going to run it down the quater mile shortly.
it will pull a mid 13 id say, raced a fg xr6t ute today and beat him lol
Post Posted: Mon Dec 10, 2012 9:10 pm
this one?
viewtopic.php?f=7&t=21798&hilit=turbo+vitara
and this could be the sister car that was built at the same time??? can anyone confirm this?
viewtopic.php?f=4&t=5618&p=73956&hilit=vitara+turbo+roll#p73956
found you old thread while searching
viewtopic.php?f=4&t=27809&hilit=turbo+vitara
Post Posted: Mon Dec 10, 2012 9:11 pm
Not to mention putting a gearbox that will cope with the power in an LJ requires ALOT of chopping.
Even fitting a 1.3l Sierra gearbox requires getting all choppy choppy.
Post Posted: Mon Dec 10, 2012 9:13 pm
A g16b isn't really an appropriate motor to turbo, many have tried before
Post Posted: Mon Dec 10, 2012 9:18 pm
i wrecked the white one, the chassie was bent and in poor condition. it had also been rolled 6 odd times. i got the cage, it is in the garden covered with hanging pot plants the birds love it hahaha. i didnt buy buy it off the original owner, i brought it off a real dodgy middle man that ripped the pair of us both off
Post Posted: Mon Dec 10, 2012 9:20 pm
[img]warning-danger-to-manifold.gif[/img]
gif is appropriate to the OP :rofl:
Post Posted: Mon Dec 10, 2012 11:20 pm
Idiots, G16bs have cast manifolds... No welds to blow! Better reinforce the floors though, they'l fall out.*
itallicsequalssarcasmfont.
I'd actually bet there's more LJs on here that have floors with very little structural integrity than ones with floors actually still attached/present as Suzuki intended.
Post Posted: Tue Dec 11, 2012 5:07 am
Name a few who have done it. What went wrong? You kinda smell like a web wheeler :lol:
Don't believe everything you read.
While they are obviously not the best motor to turbo it can be done with good results. People were saying that the Gti motor was no good to turbo back n the day. Now there are heaps of them.
Post Posted: Tue Dec 11, 2012 6:33 am
Hey Zac,
About time you show the world a few pics of your beastie huh?
Get the front diff all sorted?
Post Posted: Tue Dec 11, 2012 7:50 am
what about supercharging
Post Posted: Tue Dec 11, 2012 8:04 am
Teamswift/redline gti have plenty to read on turbo conversions http://www.teamswift.net/viewtopic.php?t=12325
These guys are a bit more crazy and run much higher boost levels. The bottom end was the first bit to fail but could also be due to poor tuning/detonation. I'm happy to be wrong but to turbo a g16b is expensive to do properly.
No doubt it can be made reliable with moderate boost and money spent on the right areas. It's not just the engine though this is for an LJ so it's a whole other level of making a gearbox fit/driveline mods.
Users browsing this forum: No registered users and 396 guests
