It is currently Thu Jul 23, 2026 1:06 pm
Post Posted: Thu Jun 18, 2009 12:43 am
A mate of mine has two 1986 MR2 motors
And was thinking of making adpator
Plate and puting it my zook , was just wondering
If anyone done this before .
Post Posted: Thu Jun 18, 2009 1:02 am
That's the 4AGE, a fairly common swap.
You'll need a T50 gearbox (or a jatco 3speed auto)
Have a search on outers. There's a fair bit of info on there about the swap. Dank is currently building a 4AGE 20V/3speed auto sierra. The build thread is on outers too.
Post Posted: Thu Jun 18, 2009 2:05 am
What's the diffence in gearboxes?
My is a 1.3 l gearbox ?
But thanks will have a look at that thread
Post Posted: Thu Jun 18, 2009 4:01 am
You will need to ditch your sierra gearbox and use a toyota T50 box. They come from the RWD sprinters.
The sierra box will hand grenade in minutes with a 4AGE or GZE.
Vehicle: WR250F/Jeep XJ
Post Posted: Thu Jun 18, 2009 5:26 am
It's not an easy road...I've been at the conversion going on 18months now...time flys.
tonight I managed to test fit the body with the motor, box and transfer all bolted in. The fit looks good, enough firewall clearance with room in front for a radiator, just, but the 20v manifold is massive and even with 2" body lift will have trouble clearing the bonnet. My zook is spua, there is a guy on 4wdmonthly forum who has a 20v swb sierra with coil prado diffs, lots of fab work.
Minimum for this conversion:
-Motor and ecu and all other components, AFM, Ignitor, Sensors etc
-T50 gearbox from rwd corolla sprinter or Aisin-Warner A40 3spd Auto from AE71 corolla.
-If going auto you need 8 bolt crank driveplate with 6 bolt torque converter bolt pattern
-You need to fab up engine mounts and gearbox mount. This can be a bolt on affair of adapter plates off standard 1.3 chassis mounts.
-You will need a jackshaft made up, one end toyota input into whatever geabox and other end zook flange to bolt to tranny. A good driveline specialist will charge around $300 to make this up. worth spending the money on.
I just started the wiring tonight. looks like i'll be cutting the loom down dramatically to reduce to an engine loom only.
The end is near... Good news is that the A40 auto is perfect fit for standard sierra gearbox tunnel. :P
My only concern is the shift points for the cable operated Auto with such a high revving motor. it's going to be an interesting outcome and I cannot wait :D
The 1986 MR2 motor...is it a carby motor? if so....wiring will be easy. There are easier conversions out there but if you have the motor there then all you need is a gearbox which go for 200+. My auto cost 200 + $760 for full rebuild and line pressure increase for a snappier change.
Post Posted: Thu Jun 18, 2009 6:39 am
Cheers mate , great help . Not sure if a carby or not ? But will find out in few days , am I able to use the mr2 gearbox because my mate said I can have the lot , full car, spare motor $ 1000 , and a mate wants the body.
Bit it looks like I need a new car to do this rebuild hehehe
Oh well have to buy another zook hahaha I'll keep your posted I'm sure if I get this motor I'll be picking your brain
Post Posted: Thu Jun 18, 2009 9:06 am
hay dank is it just the rocker cover or the whole top end that sits too high?
if its the cover surly it could be shaved abit? :?
Post Posted: Thu Jun 18, 2009 3:52 pm
The Intake manifold sits up about 1-2inch higher than the top of engine/rocker cover. Due to the angle of the motor/gearbox its only about 3-4 inches of the top front of the intake manifold that may be an issue as the bonnet sweeps up from that point.
I can shave it and reweld as the top part is steel, its no problem just an observation I made last night. :D
Post Posted: Sat Jun 20, 2009 1:06 pm
This is a turbo 20Valve in a Sierra with no body lift and spua, it clears the bonnet and has no issues with sump clearance. Mate the MR2 is a rear engine car you need a gearbox from a front engined rear wheel drive that has the correct bolt patern for am "A" series Toyota block, T50 is the one that fits that criteria.
Post Posted: Sat Jun 20, 2009 1:18 pm
how is that clearing the bonnet? there is a fucking great big hole cut in the middle of it.
Post Posted: Sat Jun 20, 2009 2:03 pm
That still counts as clearing doesn't it Shep? If it doesn't clear, just cut!! :twisted:
Post Posted: Sat Jun 20, 2009 3:15 pm
thanks for the posted pics , very inspiring !
But better get my zook back together first
Haha if it will stop raining for long enough
Rebuild on the side of the road , what joy?!?!?
Post Posted: Sat Jun 20, 2009 3:23 pm
Looks like I loss my air con ? Looks very tight
But small price to pay ? Next step gearbox .
Post Posted: Sun Jun 21, 2009 11:41 pm
any tech further links of that 20v?
Post Posted: Mon Jun 22, 2009 1:14 am
also don't coilies have slightly more room under the bonnet ?
Post Posted: Mon Jun 22, 2009 3:12 am
i think there more angled arnt they?
Post Posted: Mon Jun 22, 2009 11:52 am
Yes that 20V car has a coily front clip, I know of another one with a 20V and a normal WT front clip, I didn't think there was a lot of space difference under the bonnet
Ths pic shows that the bonnet bracing has been removed but the WRX style scoop is toward the back of the bonnet and doesn't aid in clearance. It is just a left over from the top mount intercooler that was on a supercharged 4AGZE prior to the 20V
To keep Shep happy I will close the bonnet and take another couple of pics to show that the engine clears the bonnet and that the hole and scoop do not assist in that clearance.
Post Posted: Mon Jun 22, 2009 1:58 pm
good on ya mate :lol:
Post Posted: Mon Jun 22, 2009 3:29 pm
Hey mate do you know what work internally has been done on that engine to run that turbo?
do you know what turbo that is?
t25?
is it running an aftermarket ecu?
cheers!
Post Posted: Tue Jun 23, 2009 3:49 pm
I had a 2 inch bodylift on my 4agze and it cleared thre top mount intercooler under the bonnet.
Post Posted: Tue Jun 23, 2009 4:06 pm
I WANT ONE gimme gimme
Post Posted: Tue Jun 23, 2009 4:28 pm
yeah they seem to start from a higher point though, the front corners are about the same height but the middle seems to be slightly higher.. would have to take some proper measurements but the coily engine bay and bonnet is actually longer due to the grill bending out futher.
these two cars have the same bumper mounted the same way notice the gap behind the bar the wt has that the coil doesn't
Post Posted: Tue Jun 23, 2009 7:04 pm
Hey I think ive seen that fha57 suzi around. Not for ages though...
Were those plates on a vit at one stage maybe?
Don't worry, It's only a suzi...
http://www.auszo
Post Posted: Wed Jun 24, 2009 6:21 am
Saam you are correct the cowl panel is higher on a coily they do not need to be as low because coilys do not have a folding windsreen but the turbo 20V pictured actually has coily guards and front and a WT bonnet because a coily bonnet wont bolt onto a WT due to the difference in cowl height.
Post Posted: Wed Jun 24, 2009 6:22 pm
torque is an issue, they are as bad as rotaries for torque. and they develop all their power up past 5k rpm. cams and timing change can fix that though. It would make a ball tearer of a zook though if you can get it crawling nice.
Lj81.
Ke20.
Baleno.
Users browsing this forum: No registered users and 354 guests
