It is currently Fri Nov 06, 2026 3:28 pm
Vehicle: 93 vitara estate
Post Posted: Sat Dec 29, 2012 7:18 pm
ay fellaz,
just wondering if anyone here has a step by step procedur on replacing the complete cv shafts in a 93 mod lwb vitara estate
i had a seach but couldnt find much
cheers pompoms
Post Posted: Sat Dec 29, 2012 8:05 pm
Left comes out easily.
Remove free wheel hub, when in free position.
remove circlip on end of shaft.
Undo 3 nuts on flange near diff.
It slides out, with a mild bit of jiggling.
Right is harder, as it has a shaft into diff,
this side needs some suspension loosening, removal of sway bar, to get enough room to remove.
Depends on set up how much comes off.
Some need to drop brake lone bracket off the strut
Post Posted: Sat Jan 05, 2013 3:24 pm
thanks for the help
all in and sorted
worst part was actually fitting the new drivers side cv as the ring around the spline was too wide not allowing it to push right in , i just swapped the new clip with the original
also all i did was dropped the complete hub off and it slid straight out..........alright with a little swaering and jiggling
thanks again another job done
Post Posted: Sat Jan 05, 2013 3:44 pm
You do realise rthat the to do lists only ever get longer, never shorter :)
Users browsing this forum: Google [Bot] and 143 guests
