It is currently Fri Nov 06, 2026 8:09 am
Vehicle: 91 vitara swb
Post Posted: Tue Jan 15, 2013 12:22 pm
hey guys
sorry im new here and had a quick look around for some threads but couldnt find any
i got a 91 swb vitara and it goes sweet in the bush tracks but took it on the beach and it went shit, was mainly rear wheel spinning so im thinking i need to get a tigher front diff
are spartan front locker diffs any good or what is a good cheapish upgrade instead of going air lockers
Post Posted: Tue Jan 15, 2013 12:33 pm
you'll want to chase up a GV steel front diff if you're going to lock it, the vitara alloy ones are the achilles heel & are known to break pretty easily.
spartan/lockrite or a chinsoong air locker copy are the cheaper options, when building up the GV diff you need to remove the GV R&P & replace it with the vitara 5.12 diff ratio, this is a perfect time to be putting a locker in.
i find my front air locker to be awesome as it takes a lot of the stress out of the front end when lifting wheels etc.
Post Posted: Tue Jan 15, 2013 12:38 pm
Surely a front auto locker would bring teh suck in sand?
Post Posted: Tue Jan 15, 2013 12:42 pm
Chris did fine down at Beachport, but he was autolocked in the bum too. :wink:
Post Posted: Tue Jan 15, 2013 4:28 pm
my gv was awsome in the dunes in tassie with the front locker.
Post Posted: Tue Jan 15, 2013 5:04 pm
PS. Suzukis can/do/should run much lower pressures in the tyres, which will help on the beach.
Vehicle: SJ51T
Post Posted: Tue Jan 15, 2013 5:21 pm
I never had an issue with my vitara in sand unlocked. In fact, most of the time I only required 2WD unless I was attempting to climb dunes. What size tyres and what pressures were you running them at?
Post Posted: Tue Jan 15, 2013 11:10 pm
i have brand new 31's and was running 18psi for a while and dropped to 15psi. i was driving along the hard sand fine but in any of the soft sand it didnt like at all. kinda sux because on our way back i saw 2 other vitaras and they were going fine
Post Posted: Tue Jan 15, 2013 11:20 pm
i run 10-12psi in the sand & float everywhere & have never rolled off a bead.
Post Posted: Wed Jan 16, 2013 6:03 am
I was running 9psi in Beachport.
Usually pick 10psi, but new staun copies had thier own ideas.
Post Posted: Wed Jan 16, 2013 4:43 pm
well i didnt win the diff i wanted to buy on ebay so will have to wait for another
Users browsing this forum: Google [Bot] and 137 guests
