It is currently Fri Nov 06, 2026 12:51 pm
Post Posted: Mon Jan 21, 2013 5:44 pm
Got me a dual case set up for the vit
After desroying my motor ive decided to rebuild the vit
Should i go Another 1.6 but with a auto or should i step up to a j20 auto
Going to try and get a sas passed and will probly run 33
Post Posted: Mon Jan 21, 2013 6:06 pm
SAS a GV & slot that behind it so you get a decent towing capacity & decent reduction
Post Posted: Mon Jan 21, 2013 6:23 pm
J20 AW4 8)
Post Posted: Mon Jan 21, 2013 6:24 pm
Setting up a steering box on a gv would be fun
The 2.5 would be reving its tits off unless u ran some big tires
Post Posted: Tue Jan 22, 2013 3:03 pm
Been playing round with gearing calculator and im not sure that the vit and sierra tc is going to be low enough
Wat do people think
Would gears in the vit case tear the sierra case apart
Post Posted: Tue Jan 22, 2013 3:07 pm
1.0L or 4.16 is probably the max you could run in compound like that (in the sierra xfer gearing).
A stock 1.3L case can handle a bit more load, but still not 4.3 (instead of 1.9) (the vit xfer gearing done)
Doing 4.3 in the vit xfer, will most likely pop the sierra case wise open.
You could consider ditching the dual setup and run a standalone sierra case with gears, providing tyre size is right.
Sierra xfer can mostly handle this type of load, but the 1.9 or 4.3 x input torque is too much for most of the gear sets.
Using the adapter on LROR etc to suit sierra jackshaft.
The sierra case would still be in the same location as running duals, unless you shorten the shaft (sierra jackshaft is the length of the vit case),
EDIT: bit more explainy
Post Posted: Tue Jan 22, 2013 3:18 pm
Yes. If you bound the tyres up you'll kill the sierra transfer.
A stock sierra can't see more than 365Nm of torque on the input shaft.
That setup could see something like 2000Nm if you have a G16B. That's a little outside of the design parameters of the sierra case, methinks.
For context, many years ago I was talking to Bill Larman (Agrover on Pirate 4X4.) He made his own portal boxes for his series 2 landrover. With his gearing setup, he could run 220:1 of gearing reduction into his portal boxes, and knew for certain that that was too much torque for them to survive under full torque, so he only ever used 220:1 reduction at idle and when he wasn't bound up. I think that Bill is the most talented/inspired/capable 4X4 builder that has ever lived, but I think this is a fail. Knowing that there's a part on your car that could easily fail if you give it too much throttle/get bound up is dumb in my opinion.
It's a very nice feeling knowing that the weak link in a car is the motor or the nut behind the wheel.
Vehicle: 2012 jimny
Post Posted: Tue Jan 22, 2013 7:03 pm
off topic but thats gold! :rofl:
Post Posted: Tue Jan 22, 2013 10:27 pm
In IFS land we call them CVs, we've been living with the knowledge for years. :roll: :lol:
Luke what diffs are you thinking of running if you go SAS? Staying Zook or upsizing?
If you're not precious about brand loyalty why not look at Hilux cases, one with 4.7s if you want crazy low. Or is it just that you got hold of that dual setup?
Post Posted: Wed Jan 23, 2013 2:49 am
Hilux case has no benifit at all
It hi range gearing i need
The 4.2 vit was enough in low but 1.1 high sucks
I got the dual cases cheap
As for front diff no idea yet
A custom sierra front diff like joe was going to make would fit nice but ot depends on wat the engenieer wants
If he will let me sas at all that is
Post Posted: Wed Jan 23, 2013 5:56 am
J20 AW4 8)
X2 you won't look back. I run g16b, aw4, vit transfer, 1lt switch light transfer, 4.6 vit diffs and 33's. Joe's been running that set up ( 1.3 transfer and 5.1 diffs) for years with no problems at all and so have a lot of his customers some of which ditched the Seirra transfer gears due to unreliableity and no warranty backup, things may have changed of course I'm sure but I still wouldn't use them if they were free.
Users browsing this forum: Google [Bot], shakes and 59 guests
