It is currently Fri Nov 06, 2026 11:20 am
Post new topic Reply to topic  [ 69 posts ]  Go to page 1, 2, 3  Next
Vehicle: Suzuki
Post Posted: Wed Jan 23, 2013 10:51 pm
I have swb vitara with lift needing tyres. I'm deciding whether to put 31 or 30 on it I want a tyre for only offroad and want something really aggressive, was looking at silver stone mt 117 extreme but they only make them in 31. I need opinions on which size I should take and what tyres are reasonably priced but also extreme
Post Posted: Wed Jan 23, 2013 10:58 pm
i have the insa turbo special track in a 235x75r15 is a bees dick bigger than a 31" MTR which are undersized & worn, they are a remold tyre... eg retread, they work well off road, bloody noisy on road & they're heavy as hell, as a play only tyre they're perfect.
235/75r15's v 31/10.5r15 :?
insa talk thread viewtopic.php?f=5&t=25704&hilit=insa+turbo
tyre dribble thread hear for some thoughts & ideas viewtopic.php?f=5&t=31704&hilit=insa+turbo
Post Posted: Wed Jan 23, 2013 11:11 pm
are you buying it for looks or for functionality?
if you're buying the best mud tyre available then the tread pattern atari suggested is right IMO - available as above or in silvertsone or simex brands... they do however suck in anything other than mud and WILL try to kill you on a cross slope.
perhaps you're better to mention the vehicle, tyre size and terrain you plan to drive regularly (including on road if you are driving it on the road) and a better suggestion can be made?
Post Posted: Thu Jan 24, 2013 5:28 am
Did you read this?
Sierra, 32's, Airlocked, 6.5'd, hopefully ruf soon
Post Posted: Thu Jan 24, 2013 6:12 am
Where do you live? That will make a difference to what tyre works best. Simex 'pedes are just amazing on slick clay, but in deeper mud they offer little advantage over other tyres and they suck on rock. They're nothing special in summer too. That means for us in Vic you'll look like a superstar on one hill and nothing special on the next.
Regardless of size or type, if your looking for an offroad only tyre you nee beadlocks to make them work properly.
Post Posted: Thu Jan 24, 2013 9:21 am
Where do you live?
profile says Goldcoast, Pac Pines... i'm guessing LCMP & glasshouse etc.
maybe look at the trepadore?
Post Posted: Thu Jan 24, 2013 9:38 am
The other option and its one used alot by the older guys is get a decent quality mud tyre thats about 70/30% mud/road and then get some Mud Chains.
Ive seen guys drive things with chains on that just defy belief.
Vehicle: Suzuki
Post Posted: Thu Jan 24, 2013 9:41 am
I live in north Brisbane and want something for most surfaces I'm thinking either mt117 extreme or otherwise treps,federals,km2 something like them and will 31s work on vitara or will 30s be heaps
Post Posted: Thu Jan 24, 2013 9:58 am
if you've got the lift & front diff for 31's i'd do it.
Post Posted: Thu Jan 24, 2013 10:14 am
In that list only the silverstones are "really aggressive tyres" the others are road tyres that are pretty good offroad.
Really aggressive (for me at least) means often bias ply, severe duty tyres like swampers, pedes, silverstone extremes, jt2's various 7.50 16 mine service/military tyres etc. stuff you wouldn't daily on.
It's invaluable though to find out what people are using/ what works in your terrain.
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Thu Jan 24, 2013 7:09 pm
Pitbulls.
What could possibly go wrong?
Vehicle: sj51
Post Posted: Thu Jan 24, 2013 7:13 pm
Im a big fan of 30x9.5
A few reasons, being narrower they sap less power,
attract less attension from mr plod and generally have a lower load rating than 31x10.5
I wish they made treps in 33x9.5
Post Posted: Thu Jan 24, 2013 7:18 pm
+1 to the tall skinny tyre theory.
the good thing about those insa turbos i posted is they're a smidge over 9" wide & pretty close to being 31" tall
Post Posted: Thu Jan 24, 2013 7:32 pm
my 31" KM2's are 9.5" wide tread to tread... contact patch measures just under 9.5 and when at 8psi they're 10.5" wide contact patch. just FYI
Post Posted: Thu Jan 24, 2013 7:37 pm
the insa's would be skinnier again if you're measuring contact patch at they're a 235 to start with.
Im all for tall and skinny.
The bad thing about the insa turbos is that they are really heavy (the retreads adds a few KG per wheel).
Post Posted: Thu Jan 24, 2013 7:40 pm
the insa weighed just over 34kg mounted on an 11kg steel 15x7 rim so that makes them around 23kgs, a 31" KM2 weighs 21.2kgs... sure it's a bit heavier, but not a massive amount.
Vehicle: sj51
Post Posted: Thu Jan 24, 2013 7:42 pm
My 30x9.5 treps are 8" wide :)
I imagine the insa's have a higher load rating.... ?
Post Posted: Thu Jan 24, 2013 7:45 pm
not sure of the actual load rating but they bag alright at virtually zero psi.
Post Posted: Thu Jan 24, 2013 9:06 pm
I'm running the Federal M/T, i've done rock and sand, but no mud yet, not had a problem in either, aired down to 16 psi in sand and towed my mates broken Jimny from DI point to freshwater road no worries, and they're only around $180 per tyre.
Post Posted: Thu Jan 24, 2013 9:19 pm
I've driven GH, Ormeau and LCMP in my old Snow White with Silverstone MT117 Extremes and Simex and I'd recommend you get Treps...
Not quite as good in deep mud but much better everywhere else.
Stekky had them (31") on his and outdrove me at GH on a big hard packed steep climb out of a waterhole. :oops:
Post Posted: Thu Jan 24, 2013 9:21 pm
Agreed. Treps are a great all rounder. I love them.
Post Posted: Thu Jan 24, 2013 10:27 pm
Just wish there was available size between 31 and 35. :(
Vehicle: Suzuki
Post Posted: Thu Jan 24, 2013 10:30 pm
Ok by the sounds of it treps will be my option anyone know how much roughly 30x9.5 are going for in brissy
Post Posted: Fri Jan 25, 2013 7:19 am
So wish they would make a sticky 33 trep :(
Post Posted: Fri Jan 25, 2013 7:27 am
got_bar_work wrote:
So wish they would make a sticky 35 trep :(
I think they would spank my krawlers.
Steve
Vehicle: sj51
Post Posted: Fri Jan 25, 2013 7:30 am
I paid $1100 for five 30x9.5x15 treps in newy
Post Posted: Fri Jan 25, 2013 9:26 am
Steve
that would be sweet. Much better priced than Krawlers too :lol:
Vehicle: Suzuki
Post Posted: Fri Jan 25, 2013 5:23 pm
Got a quote on kumho mud tyres today. What is better or preferred more kumho or treps and are km2 any good compared to treps
Post Posted: Fri Jan 25, 2013 5:26 pm
personally the cum-hoe kl-71's look like they'd bring all the boys to the yard, they just look ghey.
i'd be looking at treps if i didn't score a set of km2's at a reasonable price the otherday.
Users browsing this forum: No registered users and 10 guests
