It is currently Thu Nov 05, 2026 11:52 pm
Vehicle: SJ70
Post Posted: Thu Jan 24, 2013 11:42 am
Hey guys,
So my sierre brake proportioning valve is stuffed.
I can get a vitara one for free but will it work?
Or should i buy a sierra one?
If anyone knows please let me know because i need to know today but i won't have enough time to go and grab the vitara one and take it back and try it.
Thanks
Vehicle: SJ70
Post Posted: Thu Jan 24, 2013 11:44 am
Forgot to mention its the rear bias valve under the car
Post Posted: Thu Jan 24, 2013 6:36 pm
I had a Sierra, now have a Vitara, thread and spanner size is the same.
No idea if it would work though.
Post Posted: Thu Jan 24, 2013 6:39 pm
This is on my 93 LWB Vit
Post Posted: Thu Jan 24, 2013 6:43 pm
Sorry big pic, it will get smaller soon..
Note the amount of bias is controlled by the lever, which attaches to A arm by a spring. You can de spring and adjust manually
Vehicle: SJ70
Post Posted: Thu Jan 24, 2013 7:46 pm
Thanks Guys!!! If the thread and spanner size is the same it should work might need to slightly bend the line.
Post Posted: Thu Jan 24, 2013 10:00 pm
Sierra and vit are totally different. Vits are load sensing. Spring to diff etc. Sierras are not.
Why is your prop valve stuffed? Pull it out and pull it apart? I have a stocko one here if needed..
2 in, 1 out valve L shape, bolts onto chassis 3/4 up the length of the chassis.
Vehicle: SJ70
Post Posted: Fri Jan 25, 2013 6:45 am
I dropped my car off at a mates as i have no time and just told him to sort my brakes out so i haven't actually seen how it can be pulled apart he just told me its seized and i know the rear brakes haven't worked in a long time.
Could i still use the Vit one and adjust manually?
How much would you want for yours posted to Wyong NSW, 2259?
Users browsing this forum: No registered users and 98 guests
