It is currently Fri Nov 06, 2026 11:43 am
Vehicle: A shed full of pieces so far
Post Posted: Sat Jan 26, 2013 8:46 pm
I've built a pair of w/t diffs over the last few months that were going to handle my plans back then.
Plans have now changed
My diffs are arb rd 208's with 4.6 nitro ring and pinions crmo front and rear and all new everything else.
I know the calmini crmo rears aren't the greatest and full floaters would be better.
Will they be of any use with 200 fwhp through an auto
I don't really want to destroy them so should I find them a new home.
Give me your opinions
Post Posted: Sat Jan 26, 2013 9:12 pm
More info is needed
max torque of engine
1st gear ratio
torque conv slip ratio
which xfer are you using
and what tyres you planning to run?
Post Posted: Sat Jan 26, 2013 9:26 pm
Max torque 275nm. 2.46 first gear. Can't find a slip ratio bit it'll most likely be a 2500 non lock up converter. 33-35" tyres. 35's might be the straw that breaks the camels back.
Post Posted: Sat Jan 26, 2013 9:27 pm
With zook diffs lt230 transfer
Post Posted: Sat Jan 26, 2013 11:56 pm
I'd say it will be a race to the scrap bin between your CW&P and your rear axles.
Post Posted: Sun Jan 27, 2013 12:37 am
I knew that's what I was going to hear but had to ask.
Post Posted: Sun Jan 27, 2013 12:45 am
Have a rear of the vitara full floater thread. Should make for a reliable combo.
Post Posted: Sun Jan 27, 2013 1:02 am
I have read that one and the thought crossed my mind and on a second read it looks even better.
Post Posted: Sun Jan 27, 2013 1:25 am
yep.
I'm in the same boat as you. 300+Nm, auto, LT230, Hilux driveshafts ..... Vitara/ F150 hybrid diffs front and rear.
just be aware that the reduction in the vitara 3rd is more than any sierra 3rd. I think the tallest vit ratio available is 4.3:1 ( your WT's are 3.7:1)
I'm running 4.625's on 33's.
Post Posted: Sun Jan 27, 2013 8:41 am
The OP is already running 4.6 R&P, so the gearing shouldn't be an issue.
I don't think there's any way a sierra diff is going to last in that application. A vitara rear based floater might work fine, but it depends a bit on your terrain and driving style. Peak input torque sounds like it will be a bit lower than what I'm running (I have quite a bit more reduction) but I'm not generally jamming the car up on rocks. I'd say you're borderline for a stronger solution perhaps than Vitara rear. We haven't broken a vitara rear R&P yet, so we don't know where the limits are.
I'd also be a bit concerned about the front.
Post Posted: Sun Jan 27, 2013 8:50 am
Seems I'm jammed between a rock and a hard place already.
Post Posted: Sun Jan 27, 2013 10:14 am
You've discovered the Suzuki dilemma...
Upsize tyres too much or add too much power and you NEED to upgrade the axles to Hilux, Bundera, MK, 60 etc etc.
Post Posted: Sun Jan 27, 2013 10:57 am
At which point part of the whole reason suzukis are more capable than larger, heavier vehicles ceases - you've levelled the playing field out based on the requirements of your driveline. The car gets wider, heavier, and has the same ground clearance as whatever the donor diffs came from.
275 Nm sounds like it would make an awesome suzuki, but in a hilux it's nothing special.
If the end result of the build is something almost as heavy and almost the same size as a hilux, how much more capable is it than a hilux?
Not bagging your build at all Mitchie.1, but that's the end point of the dilemma. In reality, my car is pretty big and heavy (for a sierra) - it's at 100" WB, and there's lots of steel in it. I'm also at the limit of what suzuki parts can cope with, driveline wise.
Users browsing this forum: No registered users and 38 guests
