It is currently Mon Aug 03, 2026 2:03 am
Vehicle: Jimny, 2 inch lift.
Post Posted: Wed Jan 30, 2013 7:50 pm
Hi, are there any reduction gears for a 2008 jimny?
Post Posted: Wed Jan 30, 2013 11:03 pm
Trail jimny gears or Seirra tcase swap.
Post Posted: Thu Jan 31, 2013 7:49 am
What size tyres are you going to run?
Post Posted: Thu Jan 31, 2013 4:12 pm
probably 30inch x 9.5, I have 225s on it atm and I've lost a lot of acceleration so if I go up a size or two i doubt ill hardly have any.
Post Posted: Thu Jan 31, 2013 4:19 pm
Do you want to retain highway cruising comfort?
Post Posted: Thu Jan 31, 2013 4:37 pm
highway cruising comfort in my car is long gone, it already jumps around a hell of a lot so I really don't care haha. But yeah I'd like to maintain the bit it currently has.
Post Posted: Thu Jan 31, 2013 4:42 pm
Btw whats the go with the trail jimny gears?
Post Posted: Thu Jan 31, 2013 5:08 pm
Trial Jimny Gears are a gear set that you swap into your existing transfer case. They give the same amount of reduction to high and low range, typically 20%, 24% and 27% depending on which model Jimny you have.
The problem with Trial Jimny Gears is that your highway speed is dramatically compromised, e.g.; Your 225s would have made your final drive ratio taller by about 8or 9%, add 20% gears and you've dropped your highway speed by 11 or 12%.
Your 2008 Jimny has a lower geared gearbox compared to the pre 2006 Jimnys so a Sierra transfer swap won't be suitable unless you do what I did and swap your gearbox as well.
My Jimny runs 30s and with the gearbox and transfer swap the final drive ratio is the same as a stock 2006 VVT Jimny with stock tyres = Good all round performance.
Post Posted: Thu Jan 31, 2013 5:18 pm
ok but if i go a size up with my tyres to a 30" and I have the Trail Jimny Gears fitted, would that even it out to a stock ratio but with 30s instead of the 205s?
Post Posted: Thu Jan 31, 2013 5:42 pm
No it will still be lower than a stocker
Post Posted: Thu Jan 31, 2013 6:58 pm
well that sucks, ill look into them anyway ust in case but if they are lower than stock by a bit ill have to pass. thanks for the tips though, much appreciated.
Post Posted: Fri Feb 01, 2013 6:59 am
If you step up to a set of 31s it may be OK with the 20% gears
Post Posted: Sat Feb 02, 2013 2:14 pm
yeah? well, ill have a look into it, but if i have to go as high as a set of 31s i probably wont do it haha, considering im on my Ps and cops just love to take our point away from us lol
Users browsing this forum: No registered users and 325 guests
