It is currently Fri Nov 06, 2026 11:38 am
Post new topic Reply to topic  [ 68 posts ]  Go to page 1, 2, 3  Next
Vehicle: 90 hardtop and 89 soft top
Post Posted: Wed Jan 30, 2013 7:45 pm
I was wondering what mods i can do to make the rear of my zook flex better. Down travel is the main concern but i dont want climax shackles.
Is there anything like tuf but for the rears.
Any links wpuld be help full, thanks in advance
Vehicle: sj51
Post Posted: Wed Jan 30, 2013 7:55 pm
im guessing you mean r.u.f
you could just relocate your shackle hanger to get the desired shackle angle
Post Posted: Thu Jan 31, 2013 6:19 am
Yeah ruf. Would i have to get extended shackles for that?
Post Posted: Thu Jan 31, 2013 7:06 am
There are probably more threads on doing a RUF than any other subject here.
Have you ever used the search function?
Longer rear springs, longer shocks and repositioning of the shackle mounts will gain travel.
Post Posted: Thu Jan 31, 2013 7:51 am
CJ jeep springs, mazda springs.
anything longer will work.
Post Posted: Thu Jan 31, 2013 7:56 am
Front or rear cj springs and do i need lifted ones or normal as i have 2 inch lifted ones now
Post Posted: Thu Jan 31, 2013 8:20 am
front springs of a cj7.
lifted will be longer, but might be too high.
Post Posted: Thu Jan 31, 2013 9:55 am
This is pretty much all the info you need. If you understand what is happening or required for a RUF then you will be able to work out what is required for the rear end.
Time to get ya tape measure out!
Post Posted: Thu Jan 31, 2013 4:40 pm
I ordered a set of front CJ springs from Tony at usa 4x4 in Melb for around $280 shipped, and some 3in longer shackles from LROR for $100 which allowed for the whole set-up to bolt straight in. Sits about 2.5in higher than stock with all leafs in the pack, however I recommend taking the longest spring (not the primary or main) out from the pack so it sits a bit lower and rides/flex's better. While the long ass shackle isnt ideal for departure angle or road handling, it's going to provide more down travel, and allowed for a bolt in set-up. This combined with RUF will be a pretty sweet set-up for me, and once the Baleno motor goes in, I look forward to testing it out. I do feel that with this set-up, raised springs (rears) in the front will be better suited than the stocks, as the suzuki items seem really soft. But I'm still yet to drop a leaf from the CJ springs yet, and if your running a light truck, it will work great.
Oh, Im not sure at this stage if the diff will hit the fuel tank, as I suspect it will. But I'm running a different tank so will be making the mounts to suit.That extra 1.5in of wheelbase is very handy in the rear.
Post Posted: Thu Jan 31, 2013 5:45 pm
1.5" extension would be FAR better in the front.
Post Posted: Thu Jan 31, 2013 5:50 pm
A combo of both would be good.
2.5" in the front on my old one was good. An extra 1.5" in the rear would be nice.
Post Posted: Thu Jan 31, 2013 6:27 pm
Some weight.
Post Posted: Thu Jan 31, 2013 6:37 pm
OK he's asking about more rear flex so forget the RUF talk.
On the rear you can move the top mounts for your shocks inwards. This allows you to run longer shocks which will allow for more travel. This is just the start. Next you may need to remove a leaf, put in longer shackles, tailshaft spacers, move exhaust tailpipe and adjust the handbrake cable brackets.
Stay away from drop shackles, those things are dangerous.
Post Posted: Thu Jan 31, 2013 6:44 pm
Obvious question - why do you think you need more rear travel? More rear travel is a bit of a poisoned chalice. The most critical time you need to get the car to balance is whilst climbing, at which point the best thing you can do to make the car feel balanced is to stop the rear flexing, because when the car is on a compound angle, rear flex will make the car want to flop over.
We've had a number of cars in the club down here with stuff all rear travel/flex and there's absolutely nothing wrong with their performance offroad.
Post Posted: Thu Jan 31, 2013 7:49 pm
A locker will get you further than rear flex atm. Oh look, i has one here for you!
Vehicle: 89 SWB zuke
Post Posted: Thu Jan 31, 2013 10:38 pm
joeblow wrote:
Some weight.
Jo has the easiest mod thus far. I now carry 20l of fuel and 20l of water in the back as far back as i can. does nothing for down travel but. only make the compressed spring compress more (and speed humps bearable)
Vehicle: 1985 lwb sierra UTE
Post Posted: Fri Feb 01, 2013 12:05 pm
Mixed leaf's u can tune ur springs flex and stiffness
Post Posted: Fri Feb 01, 2013 3:00 pm
yelozuki:
What are the specs on your rig atm?
Post Posted: Fri Feb 01, 2013 3:18 pm
JrZook wrote:
yelozuki:
Good question, cos one min were talking about getting more flex out of the rear then were talking about ruf :?:
Post Posted: Fri Feb 01, 2013 3:54 pm
If you knew what was involved in a RUF you would understand the relevance of it being mentioned in relation to the rear.
The process of gaining more artic via longer springs is the same front as rear.
Post Posted: Fri Feb 01, 2013 5:04 pm
flex is over rated
Post Posted: Sat Feb 02, 2013 7:38 pm
:roll:
Oh that's right RUF that's what dogs do oh my bad :hey: :kissmyarse:
Post Posted: Sat Feb 02, 2013 11:15 pm
What..
Post Posted: Sat Feb 02, 2013 11:39 pm
KEENSY found the crack again....
Post Posted: Sat Feb 02, 2013 11:50 pm
even this girly coil sprung IFS vitara owner understands the relevance of the theory behind RUF being used to put in a longer spring that works in the rear to gain more flex. Image
Online
Post Posted: Sun Feb 03, 2013 12:54 am
I'd rather narrow the spring spacing than fit longer springs.
Post Posted: Sun Feb 03, 2013 1:13 am
And why so?
Post Posted: Sun Feb 03, 2013 7:19 am
Hey I understand about fitting longer springs ,I was just emotional (a little tippsy ) and took ofence to want 33s post about ruf.
But no one actual said "oh u mean the same principle as ruf but in the rear "that's all I was saying about us jumping around topic my bad sorry for being a dick
Post Posted: Sun Feb 03, 2013 8:01 am
JrZook wrote:
And why so?
Reduced roll stiffness and more articulation without any effect on axlewrap or spring rate.
Vehicle: 2018 DMAX
Post Posted: Sun Feb 03, 2013 10:42 am
Why don't people like flex? My bucket was more capable/balanced unlocked on 235's with heaps of flex than it was single locked on 31's with really crap flex. It didn't flop as often with the extra travel...
Users browsing this forum: No registered users and 59 guests
