It is currently Fri Nov 06, 2026 8:09 am
Post Posted: Sat Feb 02, 2013 5:04 pm
just put in another 5 speed gearbox into my bro's sierra and i can't seem to get any gears i tryed the old box which was working fine when pulled out and can't seem to select any gears in that box also i have pulled off the gear selector stick and put back on am i missing sumthing here
Post Posted: Sat Feb 02, 2013 5:06 pm
G/box bush at the bottom of the stick I'm guessing or you don't have the gates lined up right.
Post Posted: Sat Feb 02, 2013 5:13 pm
cheers and what u mean but the gates not lined up right!
Post Posted: Sat Feb 02, 2013 5:15 pm
Need to make sure all the gates are lined up so the stick goes into the right place.
Was there a bush at the bottom of the stick? If not that I'm sure would be your prob.
They are cheap to buy :-) someone on this forum sell them. :-) :-)
Post Posted: Sat Feb 02, 2013 5:21 pm
ok no worries at all and yes the bush is fine and the stell washer think the gates might not be lined up any idea's how to line them up have no idea!
Post Posted: Sat Feb 02, 2013 5:23 pm
I'm sure there are photos somewhere on here. Have a look using the search fuction. :-)
Post Posted: Sat Feb 02, 2013 5:25 pm
no worries will do cheers great help
Post Posted: Sun Feb 03, 2013 7:03 am
Just make sure that the three notches on the selector rods are all in line across - You can move them with a screw driver or such.
Post Posted: Sun Feb 03, 2013 9:47 pm
yer got it all sorted thanks guys great help now the only problem is now is that the car wont kick over lol hooked everything up starter motor kicking out heaps of power battery is all sweet even tryed to jump start it but still not turning over i earthed the starter etc etc what am i missing
Post Posted: Mon Feb 04, 2013 6:50 am
Is the starter spinning? If so it's the gear throw out (Bendix) that is stuck.
Post Posted: Mon Feb 04, 2013 2:21 pm
no worries at all and how do i fix this any idea's been great help so far
Post Posted: Mon Feb 04, 2013 2:24 pm
Pull the starter out and see why it is stuck and fix it and just a thought - It is not connected the wrong way round is it? IE solenoid to ground?
Post Posted: Mon Feb 04, 2013 3:56 pm
got it all sorted now was just a wire on the dizzy that broke off thanks guys for ya help all working good now
Users browsing this forum: Google [Bot] and 139 guests
