It is currently Fri Nov 06, 2026 12:50 pm
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2
Post Posted: Sat Feb 02, 2013 6:06 pm
Yeah illegal
Post Posted: Sun Feb 03, 2013 11:18 pm
for those wondering about the 60w work light
this is one 60w in a spot beam, second pic is zoomed in, the third and forth pics are my 55w hids (pair of)
This is by no means the be all and end all of testing or comparisons, but it's a good start
Post Posted: Mon Feb 04, 2013 1:55 am
Nice - but without a way to gauge the distances, not that informative.
Now - back up the vehicle to double the distance, and repeat - I'm betting the LED will be out of range and the HID still going strong.
Don't get me wrong, LEDs have their place, as a flood beam work light they excel, but as a 60W "spot" beam, not so hot, and this is personal, my concept of a work light is to illuminate the work area, so a work light would not have a spot beam.
To achieve high intensity output, LED lamps need to have multiple LEDs, focussing multiple light sources onto a single point (which is the concept of a spot beam) just does not work, you can achieve it at one distance only move closer or further and you're no longer in focus.
Post Posted: Mon Feb 04, 2013 8:12 am
what kind of distance is that?
I reckon my light bar does ok by itself, for where I use high beam, which rarely has more than a 100m straight stretch anyway
Post Posted: Mon Feb 04, 2013 10:25 am
That's around 90m royce. Also thats 110w of HID vs one 60w LED
I didnt have enough room to recreate it at longer distances, but the people that see them in person are blown away. yes you need to focus them beam if you want distance, but thats not the point, you get flood and distance.
Vehicle: 2012 jimny
Post Posted: Mon Feb 04, 2013 5:56 pm
on the light bar issue........ so if i had twy 10-20inch bars on the roof but spread apart it would be ok?
Post Posted: Mon Feb 04, 2013 6:52 pm
Correct, the height restriction is no longer (used to be no lights above x amount of cm's)
Vehicle: 99 Grand Vitara
Post Posted: Tue Feb 05, 2013 2:07 am
With the light bar issue, is it only for forward facing lights or all lights? And will you still get done if they're not wired up?
http://www.strictly4x4.com.au
Post Posted: Tue Feb 05, 2013 6:39 am
I would buy HIDs again, mine are awesome and have a great spread aswell as distance.
Will be keen to see a light bar on my roof to get some wide angle spread, but I'll happily just wheel with what I've got currently.
Post Posted: Tue Feb 05, 2013 10:18 am
what do you mean klutched, as in number of lights or pairs?
Post Posted: Tue Feb 05, 2013 11:00 am
I haven't jumped on the LED trend yet but i'm all for it.
To my knowledge in Victoria you can only have 4 forward facing lights, the two standard headlights and the 2 additional. Must be seen as a pair eg ARB's
Don't know the exact height limit, but not on the roof for on road use. (I have been done for that one!)
Anyone had any dramas with light bars and the boys in blue?
Post Posted: Tue Feb 05, 2013 11:08 am
what about the 80 series landcruiser's etc with the quad headlights standard, pretty sure the rule was 6 forward facing lights?
Post Posted: Tue Feb 05, 2013 11:16 am
Yeah 4 sure, must be six ill have to look it up.
I had six forward facing with a grumpy cop. the two driving lights on bullbar (one had blown globe, must be working if on car) and the two on roof.
Post Posted: Tue Feb 05, 2013 11:20 am
The whole even number of lights in QLD is a bit of a grumpy cop scam I reckon
I am sure in the old all about light vehicle modifications booklet you could get from there was no mention and the illistration they used to indicate things like no rod holders and aeriel mounts and stuff had 3 lights on it anyway
Saying it has to comply with an ADR not written to cover the lights and indeed even says the lights have to be 600mm apart (I dont have 600mm of room to fit lights!) is stupid, same ADR IIRC says no lights more than 1400mm off the ground, which is also allowed here
Users browsing this forum: Google [Bot], shakes and 62 guests
