It is currently Thu Jul 23, 2026 7:49 pm
Vehicle: 92 Suzuki Sierra
Post Posted: Mon Jun 29, 2009 10:46 pm
Whats the reason why you cant just reduce the lowrange without touching the highrange? i understand it mgh be space issue with ultra low ratios but wht if you just wanted'one of the smalle reduction options
Its one of those things that i stay of for a long time (messing with the gearing)
Post Posted: Mon Jun 29, 2009 11:51 pm
I know that this is a terrible photo but it will help explain:
The gearing cannot be changed to lower one half and not the other because of the design that suzuki came up with. If you look at the set of gears that are not in the case you can see that there are two 'levels' on the bottom two shafts but on the final shaft (at the top of the pic) there is only one gear. This means that they all spin dependant on each other and therefore gearing has to be of equal overall size so it all sits correctly.
Probably a bad explanation but someone might fix up if there is error
Post Posted: Tue Jun 30, 2009 2:36 am
will dig out the factory service manual, learn it, then come back to your explenation, but cheers :)
Vehicle: '92 Sierra
Post Posted: Tue Jun 30, 2009 12:29 pm
You're chasing my dream Santos. I asked this question a couple of weeks back.
Users browsing this forum: No registered users and 221 guests
