It is currently Sun Aug 02, 2026 7:04 pm
Vehicle: 2004 Jimny 1.6
Post Posted: Wed Mar 20, 2013 8:41 pm
Just trying to find out build quality, anyone got one?
Post Posted: Wed Mar 20, 2013 8:50 pm
a link would be handy for those that CBF'd trawling ebay for the one you're talking about.
Post Posted: Wed Mar 20, 2013 9:42 pm
https://www.bbta.com.au/products.php?pr ... Compressor
There you go
Post Posted: Wed Mar 20, 2013 10:20 pm
Yes I have that exact one - very good.
Post Posted: Wed Mar 20, 2013 11:35 pm
I dunno, the add looks crap..... "made by the worlds no 1 compressor manufacturer" but doesn't say who :roll:
Looks a million dollars cos its gold :rofl:
Can inflate your average 4wd tyre quick......as long as its a small suv tyre :lol:
Looks like junk to me, I'd stay away.....but thats only my opinion :wink:
Post Posted: Thu Mar 21, 2013 6:18 am
150l/m? I call BS. That's 5.3cfm. The Arb twin piston does 6.5cfm and needs up to 70A to do it. If this thing can do 5.3cfm at 45A then it's way more efficient than anybody else's compressor, in a way that makes me highly suspicious.
Steve
Post Posted: Thu Mar 21, 2013 7:14 am
Steve
I'm guessing that they measured the flow at 0psi.
Post Posted: Thu Mar 21, 2013 7:31 am
Which is kind of like claiming your car's economy is zero liters per 100km (measured whilst its rolling down a hill)
Steve
Post Posted: Thu Mar 21, 2013 7:39 am
Steve
Wandering off topic but the EU issued a report about the manipulation of fuel economy figures a couple of days ago. One of the revelations was that although the rolling load test must be done in two directions the rules don't state that they have to be done in the same place so both runs could be done downhill (up to 1.5 degrees) :roll: :
http://www.bbc.co.uk/news/business-21759258
Post Posted: Thu Mar 21, 2013 8:11 am
Fuel economy figures make me rofl. Ferrari have built a car that officially achieves 0.0l/100km (urban cycle) It can run on batteries for exactly the duration of the EU test. Thereafter, as the test rolls into the extra urban cycle it consumes about 20l/100km, so it's "urban" figure is 0.0 and its extra urban homes out at 12.5 or something. It's not a production model, but it does show how the test can be fiddled to make a car look awesome. The Prius is another example. The widow sticker is awesome, but in reality their nothing special.
Vehicle: 91 WT 1.6EFI
Post Posted: Thu Mar 21, 2013 8:22 am
Just goes to show how easy it is to misinform today's consumer.
Ok back on topic
Post Posted: Thu Mar 21, 2013 8:27 am
I have a cheapo compressor, advertised at 200psi, it struggles to get to 40 - the gauge does go up to 200 though!
Post Posted: Thu Mar 21, 2013 9:46 am
I got a similar one it does ok
I have a 6l air tank on it as its mounted in my cab
It will reseat a 35 bead
Its got nothing on my twin piston arb in my ute
That thing is crazy
Vehicle: WR250F/Jeep XJ
Post Posted: Thu Mar 21, 2013 10:15 am
I have searched far and wide for a compressor to rival the Twin ARB unit that matches it for size, output and capacity and there is nothing on this earth that I can find which matches it for suitability for use in a 4wd. There are some industrial units kicking round but they would be hard to adapt.
On topic that just looks like another Chinese compressor with some gold anodising. You get what you pay for! $550 for the ARB unit I think is good value for money considering the performance.
Post Posted: Thu Mar 21, 2013 10:38 am
X2.
I crunched the numbers and setting up even an engine driven compressor that matches the performance of the twin piston compressor will cost almost as much and be a massive headache to sort.
Steve
Post Posted: Thu Mar 21, 2013 12:01 pm
I don't know about the amps/flow/psi flow rate or what ever (Can't be bothered to work it out) but I have had one for over a year and find it inflates tyres that are flat or low on pressure in a reasonable time and still works fine but the leads were a bit short for a Maxi van so had the make longer ones - Good value I think.
Vehicle: Zookless
Post Posted: Thu Mar 21, 2013 4:42 pm
That compressor looks VERY similar to mine.
I mounted it under the bonnet in early 2006. It's still going strong.
As Tony says, it works well and inflates tyres in a reasonable time...
The only difference between mine and that one is, mine doesn't have the gold :blingbling:
Vehicle: 93 Vitara -itty bitty lift
Post Posted: Thu Mar 21, 2013 5:35 pm
bushranger compressors can be had for an extra $60 and seem to be reliable even if they arent the fastest out there
Vehicle: Suzuki Jimny 2009
Post Posted: Thu Mar 21, 2013 5:41 pm
I have the BBT one and it works fine. Don't use it much now I have one built in. Might not have the flow rate claimed but it works. It is quite large so check out the dimensions. The size is one reason I don't carry it round any more. Took up nearly as much space as a 20 l jerry can (well not quite but you get the picture)
Post Posted: Thu Mar 21, 2013 5:50 pm
Yours must only look half a million dollars then :deadhorse:
Post Posted: Thu Mar 21, 2013 6:13 pm
tonyevans wrote:
...... find it inflates tyres that are flat or low on pressure in a reasonable time.....
How long is 'a reasonable time' ? I have one of the small Chinese compressors and it takes forever to inflate the Vits 33s from 10psi to 23psi, mainly because I have to stop for some time between reach tyre to let it cool down. It takes something like five to ten minutes per tyre plus cooling time.
Post Posted: Thu Mar 21, 2013 6:51 pm
Never had a problem with the BBT one shutting down and it was pretty fast. For $99 the only issue I found was the size.
Post Posted: Thu Mar 21, 2013 9:32 pm
I have one and am now considering an ARB comp.
the first time I used mine it seized within a second. I stripped it, cleaned the rust from the bores, and greased it. It's been working ever since but I don't trust it. It's not as fast as my previous $100 single cylinder compressor.
Vehicle: '94 suzuki maruti
Post Posted: Thu Mar 21, 2013 9:51 pm
i bought a tigerz11 compressor, got lucky and got it for $100 second hand but unused still in box... and i think its great. only had it 6 months but its been used a lot. usually has to do my 31's from 7-30psi and and a mates 33's from 10-35psi so gets a decent workout... yet to have a drama. they're cheaper than the ARB compressors and are about the same speed. i wouldnt have paid $220 new for one, but after using one i'd definitely take it over other similar priced brands.
Users browsing this forum: No registered users and 327 guests
