It is currently Sat Aug 01, 2026 8:01 am
Vehicle: sj80 coily
Post Posted: Fri Mar 22, 2013 10:20 pm
Does anyone know what the spline count on a 94 vitara is front and rear.
Post Posted: Fri Mar 22, 2013 10:25 pm
spline count of what? let me guess steering shaft :lol:
22 spline front diff & 12 bolt rear if your looking at lockers.
Vehicle: sj80 coily
Post Posted: Fri Mar 22, 2013 10:30 pm
Can you get a front locker for them , also I'm after a gv steel housing are they the same spline
Post Posted: Fri Mar 22, 2013 10:39 pm
yes you can get front lockers for them, the GV steel diff has a retarded diff centre that is vacuum operated instead of free wheeling hubs, you'll need to remove all the GV crap & fit a vitara 5.12 R&P as the ratio's are different.
this is a perfect time to fit a locker, you can either stay with the 22 spline front end & get a locker to suit or upgrade to 26 spline (RHS CV & LHS axle + 26 locker)
there is heaps of info on this swap floating around.
viewtopic.php?f=1&t=17866&hilit=GV+steel+pinion+mount
viewtopic.php?f=5&t=31632&hilit=GV+steel+pinion+mount
viewtopic.php?f=5&t=16328&highlight=steel+diff
viewtopic.php?f=5&t=17748&highlight=steel+diff
viewtopic.php?f=5&t=15792&highlight=steel+diff
viewtopic.php?f=5&t=15420&highlight=steel+diff
viewtopic.php?f=5&t=13816&highlight=steel+diff
viewtopic.php?f=5&t=13533&highlight=steel+diff
happy reading :P
Vehicle: sj80 coily
Post Posted: Wed Apr 10, 2013 4:33 pm
Thanks mate i ended up purchasing a calmini anvil housing instead that should fix the front end issues
Post Posted: Wed Apr 10, 2013 4:54 pm
you will still need the GV steel "3rd" member
Vehicle: sj80 coily
Post Posted: Thu Oct 03, 2013 9:41 pm
What gearing did you fit in your vit to run 31s .
Users browsing this forum: Google [Bot] and 56 guests
