It is currently Thu Nov 05, 2026 3:59 am
Vehicle: 98 Jimny
Post Posted: Sat Mar 23, 2013 11:28 pm
Hi guys/girls i have recently broke my transfer case mount which has caused my rear tail shaft and the transfer case to sit on a nasty angle. the mount is fixed now but the joint between the transfer case and the tail shaft is spitting all the grease out !!!! :( WHAT DO I DO TO STOP IT SPITTING THE GREASE OUT??
Post Posted: Sat Mar 23, 2013 11:40 pm
Replace the CV boot. Common problem.
Vehicle: 98 Jimny
Post Posted: Sat Mar 23, 2013 11:43 pm
:) Picture :)
Vehicle: 98 Jimny
Where do you get a CV BOOT from ????
Post Posted: Sun Mar 24, 2013 4:32 am
CV BOOTS are available AT SUZUKI !!!!!!!
or try a CV SPECIALIST.
MY BUILD THREAD HERE!!!!!
Post Posted: Sun Mar 24, 2013 5:27 am
It's not a CV boot. the rubber is inside and is bonded to the the metal. You can buy a whole new tailshaft for about $600.00, or second hand $200.00. Once the bond breaks sand etc. gets in and the CV shits its self. The wrecker I bought mine off says you can put a boot over the top but I can't see how.
http://www.suzistore.com.au/onlinestore ... 31-30.html
SHAFT TAIL INTER MANUAL<br />Item code: 27101-81A21G
$475.00
Product details
Sort by
Product Name +/-
Manufacturer:
Select manufacturer
Results 31 - 37 of 37
Vehicle: 98 Jimny
Post Posted: Sun Mar 24, 2013 6:31 am
are you sure that is the right shaft??because in the picture its not the right one :?
Post Posted: Sun Mar 24, 2013 9:21 am
It is a common problem on the Jimny, and yet another reason why the Sierra Transfer swap is a popular option because it eliminates that shat altogether (beside the gearing advantages it provides). Kits from companies such as Offroad Armory in the UK will set you back about $300 delivered. Add a second hand WT Sierra transfer for something like $100, and a front WT Sierra driveshaft to use in the rear of the Jimny for say $50 and you're well ahead of a $600 new driveshaft, with the added bonus of a 6% reduction in High Range for slightly bigger tyres. Down the track, you have the flexibility of buying even lower reduction gearsets for full-blown awesomeness!
Post Posted: Mon Mar 25, 2013 7:12 pm
BAZZOOK wrote:
http://www.suzistore.com.au/onlinestore/four-wheel-drives/jimny-sn413-g13bb/transmission1744256939/results,31-30.html
Because it's the INTERmediate shaft, goes between the gearbox and transfer.
Post Posted: Mon Mar 25, 2013 7:21 pm
I had no idea these things were bonded on the shaft. I shouldve pay more attention when I did my WT mod.
Surely though you would be able to source a generic boot from somewhere and band-it-clamp it on?
Post Posted: Mon Mar 25, 2013 7:45 pm
Two zip ties and an old bike tube ;)
Post Posted: Mon Mar 25, 2013 7:46 pm
I have a Jimny shaft with intact joint $150 in Brisbane
Post Posted: Mon Mar 25, 2013 7:59 pm
essentially, yes... but band-it's are stainless steel zip ties.
Post Posted: Mon Mar 25, 2013 8:34 pm
Do I remember an aftermarket product for sale on eBay a while ago?
Users browsing this forum: Google [Bot] and 366 guests
