It is currently Thu Oct 22, 2026 5:21 am
Post Posted: Wed Jan 07, 2009 9:55 pm
Will the stock manual Grand Vitara 4.3:1 ring and pinion work with a front vitara diff center in a GV diff housing?
I want to convert to the earlier manual hub system but keep the stock ratios.
Post Posted: Wed Jan 07, 2009 10:01 pm
I guess it will be like fitting an airlocker to a GV, the right hand cv wont clip into place but that isnt too much of a concern
Post Posted: Sun Jul 12, 2009 4:02 pm
Gravity powered, did you end up doing the swap?
& Royce, wouldn`t the cv pull out when the r/h wheel is cocked?
I want to do the swap after frying my 4wd control module in the middle of nowere fri nite. if I don`t run the module I can`t burn it out again!!!!!!
Cheers.
Users browsing this forum: No registered users and 174 guests
